At a guess, the rears will be either 272mm or 276mm solid rotors and I believe this is the std sizing for most of the Golfs / Octavias except for the GTI PP.
Fronts on the MK3 RS are 340mm. I was reading the other day that MK6 Golf 118tsi fronts have been 312mm (MK2 RS size) for a while so at a minimum you'll have 288mm but possibly 312mm fronts.
Given how different peoples driving styles are (eg: I went down a long hill (Mt Ousley) the other day with just 3 dabs on the brakes of our 1.8 tonne Craptiva; the Mazda 2 (1.2 tonne?) in front of us was riding the brakes all the way down. I wouldn't have a clue if the standard brakes are up to the tasks required for your usage.
Keep in mind that the brake rotor is just a big heat sink to remove heat from the pad & brake fluid. If your braking overcomes the heat dissipation ability then the pads or the fluid overheat & lose efficiency. If that's happening then maybe look at better pads with a higher heat rating & better fluid (maybe not possible as it's probably class 6 low viscosity fluid) before upgrading to a bigger system.
Also, IMO, the rears don't have to be huge to work well.
