Results 1 to 3 of 3
Thread: Headlight fail on driver side
    Jun 2011
    Abbotsford
    My wife has a 2008 NB and the headlight stopped working on the drivers side.
    No parker, main or high beam.
    I had a new headlight put in on the passenger side a few months back as #3 son clipped it and broke the lens in a driving lesson.
    99% sure all was OK when we got it back
    Passenger side works.
    Fuses are fine - but you aint going to blow 3 fuses.
    Ideas??
    Mar 2013
    Brisbane QLD
    The plug on the rear of the lamp is crap..seen this before..the plug is held onto a mount plate and you push the headlamp back into the plug to make the connection...remove the headlamp and refit it nice and tight back in then try... sometimes works..if not you might need to mod it a bit to make better contact...headlamps can be a bugger to remove... VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jun 2011
    Abbotsford
    Thanks
    It can go back to the shop.
    I aint learning how to pull NB headlights out
