Thanks guys
Originally Posted by
huss
From what I know GolfMan, You make a couple precise measurements, take a diamond tip saw, say a couple prayer's, then cut the springs.
Hahaha thats it. I have spend many many hours searching and have come to the same conclusion. Its the easy way out. Hard way (and has been done before with success) Is to actually cut a section of the strut and remove what ever desired length. Insert Golf MK1 strut inserts because their shorter. Buy Golf mk2 front lowered springs and top spring cap? Or coilover sleeves. Seems like a too much stuffing around. I am willing to try it one day though with a spare set of struts. Till then Ill stick with the diamond blade.
I was never gonna expect significant performance increase bolting twin carbs on a flogged out, bog standard FN 1.6 engine. But There is some slight performance increase, seems to have more poke through the mid rev range. It is a bit quicker but not quick enough. Sounds great though. Fuel consumption is a little higher but not so much that Im worried about it. Never been one to care about fuel consumption anywho. The way the carbs are set up I believe will work better for a 1.8L. Include a nice camshaft and I reckon it will be enough for these old passats. I could stuff around with the 1.6, bore, port & polish, cam, gears etc....But thats just wasted money when a mk3 1.8 will bolt in
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
