Results 1 to 10 of 13
Thread: Passat B1, 4A-GE:1.6l 20v
    Apr 2009
    as u can guess by the title i was looking up engine with a bit more power for my B1 passat 1975, was wondering if any of you knew if the toyota 4A-GE:1.6l 20v would be a good engine to fit,
    please reply on what you think, if it would cost too much, too much of a hassle, or if its not worth it, please comment and give me some ideas, any constructive information would be appreciated, thnx guyz
    Jun 2007
    Eastern Suburbs Melbourne
    I think it's too much hassle and not worth it.
    It would be easier to fit an upgraded VAG engine. This could be a cheaper one like a 1.8 from a mk 3, to something more expensive and powerful, like a 1.8 KR 16V (139HP standard), and if you really want to do all out, you could do a 20VT conversion.
    I don't see the need to put a toyota engine in. you'll just create unessecary hassles for yourself
    i like volkswagens
    Thats a great motor but as commented above, a VAG one would be much easier to fit. I'd look at a 2E from a MK3. Should have next to no problems bolting it it.
    Deciding on a carb to make it run will be the biggest issue. Unless you convert the car to injection, which will bring it's own dilemmas.
    Sep 2006
    Brisvegas
    if you were to do a 20v conversion make sure its a silvertop version. but i woudnt bother with the 20v if you were to put 4AGE in anyway, they are a fun engine to have but the 4AGZE is well supercharged. And the normal 100kw 16v version is cheaper and a few cheap mods will get it up to the same power as the 20v had anyway.
    In all honesty i agree with Jarred
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Mar 2007
    Hobart
    I had a Corolla SX with the 4A-GE - awesome engine but absolutely no torque. From memory the little torque it did produce was above ~6,000rpm. If you like driving constantly in the 5-7,000rpm range, then go for it. Otherwise, go a VW unit of some sort.
    2018 Golf GTI, Manual - gone.
    2017 Golf 110tsi Trendline, manual (gone - gladly)
    2007 Golf GTI, Manual, (gone - sadly)
    1978 Golf GLS; 1972 Superbug, (memories)
    Camden, Sydney
    Get a 1.8 Golf engine, bolt it in and fit all your ancillaries.
    The engine will be 20 years newer and will make your car go like a rocket
    Mar 2006
    Canberra
    Golf Loon wacked a 1996 SEAT Cordoba in my B1 with little hassle, with the exception of the oil filter housing if I remember correctly and the car went like a rocket as stated. I have been told that most of the early VAG stuff will fit even the 2litre stuff.
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Jun 2008
    Ringwood East, Vic
    I put a 1.8l from a '91 Mk1 Cab in my '76 Audi Fox (Passat B1). Threw a 32/36 Weber carb on it from a 2l Escort (rejetted to suit). 5 spd out of an Audi 80cc back a few years ago. It got around pretty well as they are nice light cars. Good fun and cost bugger all!
    I saw one a few years ago which supposedly had a Nissan Pulsar 1.8l. Not sure how that worked but I imagine anything non-VW/Audi would be a lot of trouble and always be a little bit wrong!
    Jul 2005
    bradbury nsw
    you can put anything in there if you work at it I saw an LS passat with a twin cam Fiat motor at the wreckers at Blacktown a few years ago
    I reckon a 5 cyl audi motor would be cool especially a 200t motor Ive even seen photos of a VR6 transplant on a german site
    Imagine a g60 supercharged golf motor ooh I better go and have a cold shower!
    Mar 2007
    South Brisbane
    You can do anything its all about budget really and preference, going for the Toyota 1.8l 20v is a awesome bit of kit, availability is good if not better than a vw engine and you have the advantage of shopping around import yards. A conversion like this won't be a 5min job your main hurdle will be getting a bell housing adapter plate made.
    I have done a 1.8l K-jet swap into a B1 passat wagon was the easy way to go and works well. Cross breading gets mixed comments i almost did it myself and still plan to in another shell
