Fitted my Gti Wheel to it.
Some Borbet Reps
Then some low
Streetmods Auto show
New wheels
Hi guys.
Im new to this forum...
I stumbled across this site today and Registered.
I own a '75 LS coupe. Was 1 owner vehicle when i bought it and garaged all its life.
has gone through a few changes over the years...
but here she is when i got her
million more pics... Will post as time goes on
Khalid
Some Borbet Reps
Then some low
New wheels
Then this happened..
My MK1 can be seen hibernating in the garage
Bought this as spares ( '75 1600 Auto ) AUS$260
will post up pics of the Strip down and respray tomorrow.
Went with British Racing Green
Thanks for looking
Love the car. Love the wheels (both sets). Love the steering wheel - you don't have a spare do you?
Hate the black paint on the yellow one, what were they smoking when they did that?
What are your plans for the Golf?
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Thanks Paul...
Yellow one was bought from some Permanently drunk dude.
I actually gave him a car stereo system for it.. HAHAHA... said it over heats after came from mechanic..
by the time i got home, after towing it, turns out entire engine was Redone and the Idiot mechanic connected Rad fan directly to the Battery. so you need to Connect wire to battery in engine bay for fan to stay on permanently till you you remove it when parked..
Yellow one i needed just for rear valence, boot, bumper and Left tail light. Sold it with Beige passat busted up panels...
The 2door is a UK import Gti... After owning it for 10 years, sold it to my cousin. ARROW Straight body. minimal rust. so still in the family
Shots of my 2door
Then did this ( flat down and Derust )
Primered
Helios Blue.
Engine was a 2.1Stroker. 1.9lTdi crank, balanced bottom, 2l polotech head ( FULL RACE ), skimmed 1.5ml, highrev retainers, 292deg cam, flowed and Ported head, Full drag box and Twin Delorto Side draughts.
Last reading, 131.6kw 307nm Torque.. Was a beast
Engine in Question
plans are same engine as this in passat...(practically done but will post up more past to present pics of the passat)
Some other cars i owned in the past:
1981 Gls
1980 Golf L
1975 Audi 80
1978 B1 ( Current Parts Car )
Oh and I personally dont have an Extra wheel like that. but, i have a few buds who hoard spares...
you fancy black? or brown... I will confirm in meantime who has a spare
Apologies for the HIJACK ...
back to the B1 ..
So removed the boot, bumper and Left taillight from the car
Got B1 to a buds shop and Stripped it down
Prepped
Primered
Painted ( British racing green )
Then the 1300 engine died on me..
And at the same time, I went to work Away from home allot.
My Youngest bro Removed the engine and installed a Mk3 2E long block
After Dyno and test drive, Broke a mounting .... Thats when she went to park for just over a year ... :'(
As she stood in sad state:
After getting married, My new wife ( Who loves OLD CARS TOO, pushed me in the right direction on completing the car and getting it going again )..
here she is mixing filler for my 2door gti ( why on the jerry can, i have no clue ) lol
So the rebuild Began....
While working away, My bro used the car... Neglected it abit yeah, motor bike slid into driver side too...
so i got back into it...
bike damage:
Now to get the Box out! Well Protected
So i got the lazy, tired 4Speed out and used the one from the Donar car ( black LS above )
4Speed out
Donar box...
Note the Difference in the Linkage setup between the '75 and '78 B1's.
Top is the '75s and bottom the '78s
The Channels on both cars are totally different. the '75 has a Low channel wit the Linkage Outside the car. where as the '78 has the high Channel with Linkage running Into the car.
In order to use the high channel setup, especially for 5speed gearbox install, requires the low channel to be Cut out and high channel welded in. Since im not good at welding, left that for now...
For anyone wanting to achieve this, Here is how a bud of mine staying few thousand km's from me did his...
The Channel Conversion
Cut out the Old Channel
Weld in the Raised Later model channel
Mountings are diff too..
Old mounting sits to rear of box
New ones are to side of box ( below taillight is mounting and brackets )
Donar box installed on my B1
Next up, Engine ...![]()
Right. so having an amazing setup, (im a carb lover BTW), on the Gti, i decided to do the same for the B1 ..
sourced an 1800 Short block out of a Jetta cli and a head modded to spec.
parts:
82.5mm 2.6 Caravelle Pistons
Rear box mounting fooked
All Fixed up
