Body and trim are the hard to get bits on the early Passats. Look to see if it's all there. Missing trims and clips will be hard to replace.
They can rust in the bottom of the rear quarters if the boot seal is leaking.
Check the carpet on the parcel shelf - if the back window is leaking it can rust under there.
Most mechanicals are Golf and are pretty easily available so don't worry if it needs wheel bearings, brakes, balljoints rod ends etc.
Take a good look at the window scrapers, they can rust badly and scratch the glass.
Main thing is to make sure it's complete
