I did a 1800 Short block from Jetta CLI. bored out to Fit 2.6 Caravelle Pistons ( Std 82.5mm ) ... Kept 1800 Crank and Rods..
made good power with a worked Carb head and Weber Carbs on golf
bolted straight on with no issues
Wouldn't a 2.0 8v from a MK3 Golf be OK? It was a straight swap into my MK2 and I kept my 1.8 head and put it onto the 2.0 block.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Interesting mod. What capacity do you end up with, 2.0?
To get technical, Its gets you a 1897cc ( 1900 ) setup..
With a 2.0l Crank, takes it to 1997cc ( 2.0l ) setup...
got 127kw with 233nm torque out of it on my 4door SA 1800 sport golf ( later model golfs ).
My 2 Door GTi had similar setup, only i had it up to 2091CC (2.1l) stroker with Tdi crank(Balanced and knife-edged) Stock rods and 82.5mm Pistons. head was skimmed 1.5mm ( on its last ) to get me a 12.6:1 Compression... ended up with 137kw and 312nm torque on that little 8v..
That looks mint,
Found this "how to" forum post, pretty much tells all
VWVortex.com - ***VW Fox 16v swap FAQ***
Just gotta get the donor car with the engine, might be hard in oz but it's a start,
Though just thinking if the 9a 8v bolts up to the Passat gearbox I have fitted the KR 16v head to this block before, hmmm and I'm guessing those 20v - 16v Audi motor are non existent in oz.
the golf is not dead.
The 9a is a 16v engine so why would you put a KR head on it?
