Bummer too hear, but looking forward to seeing the rebuild
I remember I got some foreign object into the old 1.6 in my yellow mk 1, the valves fared much worse!
Frank's motor has been living on borrowed time. We did all we could to prolong the inevitable but today it's time ran out.
We've decided to rebuild it rather than replace it with something more modern.
It's a period high performance 1600 so for nostalgia and economy's sake it will remain 1600.
This will also give me the opportunity to clean up the wiring and paint the engine bay.
The previous owner claimed it had Scat brand valves.
There's a fair bit of old damage in the chambers from foreign objects including what looks like an M6 nut impression.
80mm Flat top pistons
The motor got real hot when it died and baked the paint right off the rocker cover.
Usual story, death by overheating.
Measured the cylinder pressures, number 2 was blowing bubbles into the radiator.
This block off plug was split and leaking water, it's not clear if this was caused by the fault, or was the cause of the fault.
Bores could be better. I think I'm looking for a set of 80.5mm flat top pistons and a rebore.
More foreign object damage, I wish I knew more of this engine's history.
M6? Wonder how that got in there and how it got out again!
Fair amount of head work evident.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Motor is out and apart now.
7? MK1 Caddy
12 Amarok
7? MK1 Caddy
12 Amarok
7? MK1 Caddy
12 Amarok
Just got a bunch of stuff back from powder coating.
7? MK1 Caddy
12 Amarok
when are you starting the engine reassembly ?
This is a really neat flaring tool I picked up from eBay, Awesome quality and a perfect flare every time.
Hey Peter
I love your work! Can I ask how much that brake flaring tool was and if you have a link to the shop on ebay?
Thanks
Martin
Back into it, life got in the way.
7? MK1 Caddy
12 Amarok
7? MK1 Caddy
12 Amarok
