7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
More progress and a whole bunch of new stuff into the car this weekend.
VW Australia's very last B1 Radiator mount.
Recent diesel radiator
New water pump
and housing
a bunch o stuff.
Didn't get round to putting these in yet. They're the inner tie rod ends, a rare find off US eBay.
These are an even scarcer item, the tiny clips that hold the chrome trim surrounding the windows.
7? MK1 Caddy
12 Amarok
Got the front brake hoses in too, one of them was a bit stubborn to undo.
Brakes bleed up OK and the pedal feels good, but I'll probably do a MK3 booster conversion after I've driven it.
These callipers are going in the bin now!
7? MK1 Caddy
12 Amarok
I was going to fit this new heater valve too but ended up using a Golf one as the orientation of this one was all wrong. Must have been setup for a LHD car I think.
7? MK1 Caddy
12 Amarok
The entire cooling system was pretty horrific, I kept finding worsre and worse stuff.
Here's some.
This is a spark plug that was used to block one of the lines.
7? MK1 Caddy
12 Amarok
and a few engine bay shots of it going back together.
After all of this I got all the lights working too.
Next is to finish up restoring the engine fan and get it back in there.
7? MK1 Caddy
12 Amarok
great work Pete! light at the end of the tunnel must be getting brighter!
Cooling system all sorted now and it's back on its wheels.
Seems to drive OK, issues with the cluster and dash blower.
I think I'd best put a MK3 booster in there, the 18mm m/c isn't going to cut it. Otherwise though the brakes seem to work.
Pete
7? MK1 Caddy
12 Amarok
Loving this rebuild. As with all your builds you're doing a damn good job making an old car newer.
Is that a Uniflow air filter? Standard Solex carb. (same inlet size as Golfs)?
Great job. Keep it up.
But I suppose you don't really need anybody cheering you on to get a job finished.![]()
