Page 19 of 40 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 394
Thread: 1980 B1 Passat Project
  1. #181
    Boronia VIC
    A couple of other photos I forgot to work into the storey line.
    We found these retro Audi wheels the other day, they're also 4x108 so we're going to clean them up as a second set.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #182
    Sep 2006
    Australia?
    Nice work mr Jones definately looking good
  3. #183
    Gosford Central Coast NSW
    Good work pete - I have a Passat radiator taking up room here that I dont want. Its from a diesel and is also a thicker, more dense core. Its yours if you want it. If you're coming to nat's PM me and i'll bring it along, or maybe one of your VIC buddies will take it home for ya???
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #184
    Jun 2007
    Eastern Suburbs Melbourne
    Looking good Pete! How far off roadworthy and rego now?
    i like volkswagens
  5. #185
    Boronia VIC
    Brakes went on today.
    See the holes in the ball joint plate and A Arm? that's how you adjust the camber. You need VW tool 40-200 to move the ball joint back and forth in it's slots. I had to make one.
    How's the offset between the ball joint and the base of the strut? Interesting geometry.
    VW tool 40-200 (PJ variant )
    Audi 80 brakes - well seasoned from racing at Phillip Island and Sandown. Need new brake hoses , these are VW at one end and Ford at the other. There's a pair on the way from GAP along with all new radiator hoses.
    7? MK1 Caddy
    12 Amarok
  6. #186
    Boronia VIC
    Replaced most of the engine mounts today too.
    Removed the last remains of the air-conditioning system.
    Snub mount was stuffed. The bracket is different to the earlier passats as the engine bay is longer.
    New mounts either side of an old one. Much easier to replace than Golf ones. The engine sits up a bit higher in the bay now.
    One of the bolts holding the front mount bracket had been snapped off in the block. Right angle drill comes in handy here.
    As the drill bit broke through it snatched the bolt and wound it nearly all the way out for me. I was able to unscrew it with pliers from this point.
    How's that for straight shooting? Not bad considering the access issues. No thread damage what so ever. A lucky save.
    Mount back in place.
    7? MK1 Caddy
    12 Amarok
  7. #187
    Boronia VIC
    Some OEM NOS wheel locks to keep those Audi Ronals safely attached.
    7? MK1 Caddy
    12 Amarok
  8. #188
    Boronia VIC
    Not too far away now, just got to fix the plumbing and the wiring.
    7? MK1 Caddy
    12 Amarok
  9. #189
    Good work Pete!
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  10. #190
    Perth. WA
    Interesting to see VW was welding the front hub assemblies back in the day ( as opposed to the forgings the Mk1's use) making me think about producing lowered front hub assemblies for the Mk1....
    Other trick with the drilling studs out Pete is to use a LH drill bit and reverse drill, comes out the same side from which your drilling
    Can you PM me the heads up on those wheel locks bud , interested in a good few sets for the increasingly rare wheels here...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
