I actually just got a keyless installed the other. Appearently it isn't so straight forward because the central locking module on our cars utilizes a pulse for lock and unlock. I believe it is two pulses for unlock and one for lock. or something like that.
Anyways, he installer told me that you are required to get an additional module that will translate the central locking signal from your car alarm in a pulse.
That's all i understood. I usually keep far away from electrial stuff in my cars.
Cheers,
Augy
Maybe the system they fitted needed that interface but I think that the one Garth has will work fine. There is only one pulse required for each operation, it just goes into a different wire.
If your installer is used to non-european cars maybe that's why he thought it was problematic.
With some thought, those relays can be configured to do all vehicles.
Well Augy your cool for sort of staying away from this stuff but, it really is quite easy (if your willing to get the old multi meter out) LOL
Gavin you are a legend, your diagrams and GOLDEN advice over the phone was enough to set me straight, I feel like driving to ADE to buy you a brewski....
now I cannot stress enough, if you are doing a keyless entry and your thinking "I better test this before I seal her up"....
MAKE SURE YOU CLOSE ALL THE DOORS as the fkin thing WILL NOT work unless doors are all shut....
the unlock works fine with doors open, u can hear it BUT, the lock will not!!
I think in the end this was really the big mystery..... Golf and I are still friends though he he.....
so its in, it works and I'm happy...... thanks to you Gav, legend!!!!
Thanks Garth. Glad that worked out.
You can check with the doors open, if you are concerned about getting locked out. You need to flick the catches in the door lock but remember to release them again by lifting the handle.
- You may not post replies
- You may not edit your posts
Forum Rules
