Results 1 to 10 of 11
Thread: WTF is going on? MK4 Bora 4mo
    SE Suburbs Melb
    Driving at speed, regardless 60 or 80, there are times where every few seconds I get a pulling feeling momentarily, almost like the car is hesitating?
    Eating a fair bit more petrol then it needs to also.
    AFM or 02 sensors?
    Thanks
    Apr 2008
    Coil packs perhaps?
    Nothing to see here...
    Apr 2008
    Have you done a scan?
    2000 Mk IV GTI
    Scan will be your biggest help...
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Aug 2007
    Five Dock, Sydney
    could be coilpacks.... is it idling ok?
    Get a Vagcom scan , I have a spare Coilpack for a late 2002> 24V V6
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    SE Suburbs Melb
    mine is an 01, AUE engine code.
    doesn't have individual coil packs, but the big single 6 in 1.
    idle is ok here and there, sometimes in the morning, or whenever hasnt been started for a while idles at 1.1K.
    does anyone nice have a scanner in s.e suburbs of melbs?
    thanks
    Nov 2007
    Coffs Harbour
    can be any above but.....check wat fuelusing
    Townsvegas QLD
    Is yours drive by wire? Clean the TB and maf, check the plugs and gap of plugs, also check all the plug wires from the plugs to the coilpack..also try this link http://forums.vwvortex.com/zerothread?id=804369
    SLAM.POKE.TUCK.DROP.DOPE!
    dont forget about the coolant temp sensor.......
    you need a scan tool to be sure.
    Mar 2009
    Southside, South Australia
    My V5 Bora started hestitating at odd moments, sometimes it was fine other times it lagged. A week later it suddenly started running really rough. Coilpack was the issue in my case.
