Results 11 to 20 of 26
Thread: "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)
    Mar 2011
    Gold Coast QLD
    Pioneer AVIC double DIN unit installed:
    Needed lots of wiring (reverse, speed sense, separate DAB antenna stuck to the window...)
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-01-avic-jpg
    Dynamat on the outside door skins:
    I was too lazy to do it properly on the inside of the doors. Taking the skins off allegedly requires removing or taping the windows glass, etc etc. I'll do it when the window clips break and I have to replace them
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-02-dynamat-door-jpg
    Picture of the center console removed to help clean the soft-touch stuff off, and to run wiring for the illuminated gear knob still to come:
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-07-console-removed-jpg
    I also cleaned out the insides of the instrument cluster. Turns out it's a crappy Bosch "MotoMeter" RB8 unit, not made by VDO, so that's gonna be fun trying to get the PIN/SKC code from using VAGTacho... NOT!
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-06-instr-clust-jpg
    Ahhh didn't know there was a non sunroof one, cool
    Aug 2007
    You can still get the SKC , but you will need the car hooked up to a decent charger as it can take at least an hr to seed the key. They can be a pain but still doable. Oh and yes the clutch is 80-90% worn, your not wrong there
    Jmac
    Alba European
    Nov 2013
    Goldcoast QLD
    Good to see another 1.6 getting done up
    Mar 2011
    Gold Coast QLD
    Photoshoot
    Photoshoot after 'paint correction' using an orbital polisher and Scholl S3 & S17:
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-w01-jpg
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-w02-jpg
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-w03-jpg
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-w06-jpg
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-w07-jpg
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    Nov 2006
    Largs Bay, S.A.
    Great job with the polishing - looks really good!
    re. horns, lower spec Mk4 were only supplied with the single horn (high pitch - hence the road runner sound), you might have the wiring in place for the dual horn system - it's usually tucked up around where the other horn is and has the same style connector on the end of the wiring.
    Mar 2011
    Gold Coast QLD
    Thanks! I couldn't find wiring for a second horn - primary plan is to replace the existing horn with an aftermarket "low" and see how it goes.
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by YellowLemon View Post
    Anything would be an improvement on the road runner sound. (Dual-tone horns give you that classy European 'parp' sound)
    Sep 2014
    Gold Coast, Queensland
    Hey mate, can you put up a link or more details on which central locking kit you went with? I have the exact same model car, and would like to put one in myself. Was it just adding the remote central locking module into wiring loom and get your keys cut on some HAA key blanks that fold up?
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by shauny View Post
    Hi mate I got this exact kit here for $19.00 -
    Remote Control Central Locking Conversion Keyless Entry KIT FOR VW Golf MK4 MK5 | eBay
    If you go with the flip keys, you'll need:
    • Remote kit - $19
    • HAA blanks cut - $40 each key
    • 2x glass transponder chips VW ID48 from keymam - $15
    • VagTacho or Vag K Commander clone from ebay - $20
    Then follow the "how to program a transponder to your car" sticky in this forum to code the keys to the immobiliser. Alternatively you could try remove the glass immo chips from the existing keys (they may be glued - have a look. It looked too delicate a job for me) and put them in the flip keys, OR glue a transponder chip under the steering column trim onto the immo induction loop, then any key will work.
    OR you can avoid the key cutting and immo hassle by just keeping your existing keys and getting this remote kit:
    CAR Remote Control Central Lock Locking KIT Keyless Entry System NEW OK | eBay
    "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-simple_remote_kit-jpg
    In terms of installation, it is very DIY-able, you only need to connect four wires. First hook up the "N/O" contacts of the central locking kit on to the ground wire (the Golf uses a negative pulse to trigger the lock/unlock)
    DIY Instructions:
    1. Remove drivers door panel. It's 5 screws and 6 clips, quite easy
    2. On the window regulator there's a huge plug with like 36 wires going into it. This harness has the 4 wires you need:
      • Constant Power (+) = Thick red wire
      • Ground = Thick brown wire
      • LOCK = Yellow/blue wire on pin 24
      • UNLOCK = Red/green wire on pin 4 (note pins 4&24 are almost opposite each other, but not quite)
    3. Most installers just mount the black control unit box in the door, it fits easy. Personal preference I ran the lock/unlock wires through the rubber wire boot in the door and under the driver's side dash & mounted the control unit there.
