Pioneer AVIC double DIN unit installed:
Needed lots of wiring (reverse, speed sense, separate DAB antenna stuck to the window...)
"Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-01-avic-jpg
Dynamat on the outside door skins:
I was too lazy to do it properly on the inside of the doors. Taking the skins off allegedly requires removing or taping the windows glass, etc etc. I'll do it when the window clips break and I have to replace them
"Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-02-dynamat-door-jpg
Picture of the center console removed to help clean the soft-touch stuff off, and to run wiring for the illuminated gear knob still to come:
"Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-07-console-removed-jpg
I also cleaned out the insides of the instrument cluster. Turns out it's a crappy Bosch "MotoMeter" RB8 unit, not made by VDO, so that's gonna be fun trying to get the PIN/SKC code from using VAGTacho... NOT!
"Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)-06-instr-clust-jpg
