![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
wiper motor electric plug conversion
I have a 2000 model Bora which has a small white wiper motor plug. I bought a 2004 model wiper motor and linkages, the plug (black) is different. I have received the black plug and wanted to convert it from tke old one and now notice that there are a few more wires than my older one. Does anyone know how to convert from the old (white) plug to the newer (black) plug?
hi Eman,
please verify the colour code you have. I checked the wiring diagram for bora 2000 and Golf 2004 and they appear to have the same colour code. Golf should have :
Pin1 green/yellow
Pin2 green
Pin3 green/black
Pin4 brown (ground)
The same colour code is showing in Etka for Bora 2000 model. Pins 1,2,3 all go to the "Automatic intermittent wash/wipe relay, on relay plate "
I will check the one wiring colors tomorrow but the wire that I want to fit onto the car is:
Blue/yellow stripe
Brown / blue stripe
Brown / red stripe
Blue
Brown/blue stripe
- You may not post replies
- You may not edit your posts
Forum Rules
