All good bud. I had one clip that had snapped where the wire attached randomly. What then happened was the wire spun free causing the reel/spool to stuff up and got all tangled and just got messed up. So ultiimately, cause of failure was the clips :| Tight fit re-installing tho!
2001 MkIV GTIRevo Stg 1 - K&N Intake - Forge DV
If you decide to fix before the plastic clips fail you can just replace the clips.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
