Turn the key off, then back on again. It'll appear for a few seconds before going out.
Hey All,
Went to look at a MK4 the other day but couldnt for the life of me work out which light is the check engine light. Can anyone tell me if its lit up in this picture or where I should have been looking?
http://i.imgur.com/YBLNV.jpg
'07 Transporter 1.9 TDI
'01 Beetle 2.0
from the left;
airbag, immobiliser, temp, brake pad wear indicator, fuel, oil level, screen washer level, ABS, Handbrake on, battery, drivers seat belt not on.
check engine light is not one of those lit in your pic
Engine warning light looks like an engine shaped icon with an exclamation mark, and is red. Cant remember which dial it shows up in, think it is the centre...
My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
'01 Beetle 2.0
you may find that any errant fault, even temporary, that is from any one of a range of sensors attached to the engine, may cause the light to come on...
