Also just be aware, I believe there is a plastic regulator replacement kit like the one you have that has broken and a newer metal one designed to permanently fix this problem.
When I first met my neighbour from across the road who had by then owned a MK4 for about 5 years, he told me the local dealer had replaced his several times over the years obviously using the plastic kits until he (my neighbour) found out about the newer metal kit and insisted that they use that one.
Cheers,
Snowy.![]()
