Results 1 to 10 of 12
Thread: Wheel stuck on!
    Nov 2008
    Northern Sydney
    Wheel stuck on!
    So after my 2nd flat in 3 weeks i started swapping over my flat to thge space savere tonight for the drive to the tyre shop in the morning.
    All going well, all nuts out, car jacked up (on super crap VW jack) and the wheel won't budge at all. I got all 4 wheels balanced and alligned 2 weeks ago at Bob Jane. When i look down the thread hole it looks like there is some copper residue that looks like oozed glue. Hand brake off etc etc.
    I put full weight of car back on wheel with all nuts out and still won't budge.
    Any idea what i could have missed? Or have Bob Jane gotten lazy and used glue to match up the holes when putting my wheels back on rendering it impossible to get the wheel off now?
    Waiting for the NRMA now for nothing better than a potentially more sturdy jack.
    2010 Skoda Octavia vRS Wagon
    Dec 2006
    Kilsyth, VIC
    First things first, loosen your bolts (or nuts on other cars) BEFORE you jack the car up and make it potentially unstable. All you need to do is crack the seal, but it's just safer to do it with the car on the ground.
    VW Bolts shouldn't be put on using a rattle gun, rather a torque wrench set to the right setting. (That and they tend to tighten over time all by themselves). Failing all else, more leverage, which I'm sure NRMA will provide by way of an extension bar on the wheel brace.
    Failling that, just use Golf Loon's method: http://www.vwwatercooled.org.au/newf...ad.php?t=10618
    edit: My bad, I'm half asleep and thought you couldn't get the nuts out, just ignore me and go about your business ;P
    Nov 2008
    Northern Sydney
    All of the loosening was done before the jack even came out.
    All the bolts are off now (i needed to jump on the standard wheel brace bar).
    It's just that the wheel still seems to be joined to the hub. Like glued on or something.
    Aug 2007
    Leave a stud on a couple of threads, and let the handbrake off, spin the wheel and thump the inner of the rim with a rubber mallet mate, never fails for me.
    Jimmy
    Alba European
    Jun 2006
    Orange NSW
    That's just Copper Anti seize. Stops the bolts from locking in the thread due to corrosion etc. Anyone worth their salt in the automotive industry uses it.
    Back the bolts off, lift it up and get a block of wood and a sledge hammer or just a really big hammer. Hold the wood against the inside rim edge and give it a good whack with the hammer. Use a rubber mallet if you have one. If the wheel budges, keep rotating it and hitting it to shimmy it off the hub.
    Nov 2007
    Coffs Harbour
    you have run over ttoooo many black cats........
    Nov 2008
    Northern Sydney
    Quote Originally Posted by JVLR32 View Post
    I'm notorious for having stuff going wrong with my cars...pity it's my passion...
    Nov 2008
    Northern Sydney
    Crisis over...with the much stabler jack of the NRMA it just took a decent belt to get it off. Bit of corrosion sticking it on. If i hit it that hard on the VW jack it'd all be over.
    Thanks for your input team.
    Jun 2006
    Orange NSW
    Good to hear mate.
    Canberra
    For the record, the correct tightening torque is 120NM (89 pounds).
    Snowy.
