Results 1 to 9 of 9
Thread: wheel offset for mk4?
    Sep 2006
    sydney yulle
    hi all im in the middle of ordering some custom wheels for the mk4, i wont give it away but there japanese wheels. Anyway the old wheels dont have the offset stamped on the back, probably cause they were made in taiwan . So i want 18s again i was quite happy with the fittment of the old wheels they just fit and the car looked good once lowered on the coilovers. So i dont want any crazy poke or anything, the cops almost done me for it last time. Im thinking 9.5 rear with et35 x18 no idea on fronts but ill probably rum 18.x8.5 but no idea on offsets anyone have suggestions? btw i refuse to use spacers or adaptors, im getting the wheels custom made so there is no need really. cheers
    GT-28-VW three hundred and something days till get licence back , couldnt resist that corrolla needed to teach it a lesson
    Aug 2009
    brisbane qld
    et35 would be fine for the front i presume
    Jan 2008
    Canning Vale, Perth, WA
    I believe theat OEM was +35,
    However, if you want to go for a 9.5 inch rim, you might have clearance issues.
    Have a play here Wheel Offset Calculator
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Canberra
    Mate I would say that with 8.5 and et35 at the front you may be getting very, very close to having contact on the adjustment collars on your coilovers, depending on which coilovers you have, and close to flush with the guards on the outside.
    On the rears with 9.5 and et35 I think you'll poke by about 6mm - 8mm.
    Cheers,
    Snowy
    what kinda of offset would you need to get a flush fitment? sorry if im hijacking your thread.
    Jan 2008
    Newcastle, NSW
    Im sure there are plenty of cars/builds on vortex with the info you seek if this thread doesnt come up with any factual info. Sorry I don't have any
    Albury, NSW Australia
    If you're worried about legal issues, you should read up on the laws regarding width.
    9.5 will be over the line.
    As for fitment, google an offset calculator - punch in some numbers and grab a tape measure to double check if you'll clear.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    8.5 et 35 has been done.
    9.5 et 35 will come down a bit to how low you are. given a fair drop. id say close to flush/a tiny bit of poke on the outside, inside will be getting close to the shock but dont think it'll touch...
    Sep 2006
    sydney yulle
    got idea im going to put some wheels on with the known JJ and go on that JJ calculator and go from there.
