Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Wheel Alignment & Balance
    Dec 2006
    Quote Originally Posted by rikard1 View Post
    only thing is the steering wheel was a little off centre before it went in and it came out exactly the same way....
    Ohh my pet hate with alignment centres...
    can the steering wheel be somehow centred without affecting alignment or do u have to undo nuts and bolts and stuff that would affect the alignment
    Yes, they should be able to do this. Once I had one of my cars come out with a between 15-30 degree offset. I told them to fix that crap up. Once they were done, they were blacklisted from places I take it to align.
    -DIDZ
    Apr 2008
    Ever since I got new tyres fitted my Golf it started pulling to the left. I took it back to the tyre place who told me that I was only noticing it then because there's much more grip/better tread. I didn't buy that excuse so I took it to a local Pedders who I'd used for two previous cars and done a superb job. This time they didn't satisfy - it still pulled to the left after a "wheel alignment". I took it back to Pedders to tell them it was still pulling to the left but was told there's no real adjustability in Golfs. So, the reason why it pulls to the left? "Because it's European and they build them so they pull to the left to make up for the gradient in the road (opposite side to us here)." What a load of bull! I couldn't be bothered arguing considering they couldn't fix it in the first place. What's weird is that the alignment specs were reasonable.
    I've learnt to lived with it now although I am led to believe MkIVs can be adjusted but there's a bit more to it than your average Falcon/Commodore/etc.
    Good luck and don't buy b/s excuses! Take it to a specialist and pay a bit more to get the job done right.
    2000 Mk IV GTI
    Dec 2009
    NSW
    Quote Originally Posted by DIDZ View Post
    yeah pi$$es me off but it was only a slight angle so im not really surprised they overlooked it ...still, it was Heasmans so if i cant trust them to do a good job then who can i trust?
    ...anyhoo i was wondering if its something i can adjust myself, like if i unbolt the steering wheel on the steering column i wouldnt expect that to throw out the wheel alignment. is that how the suspension shops centre the steering wheel?
    rikard's dating faux pas #067 - "hey i had a really great time tonight, i feel like i owe u something ..would u take $20?"
    Dec 2009
    NSW
    Quote Originally Posted by dubbed View Post
    how long after u got ur new tyres did u get ur alignment?
    Canberra
    The problem with the average "alignment/tyre experts" is that they adjust the tie-rods to set the Toe and figure their job is done.
    I had the problem you describe after fitting a new front anti-sway bar and it stemmed from when the Subframe bolts were loosened and the Subframe was lowered and bolted back up, the Subframe had moved ever so slightly, just enough to change the Caster from one side to the other.
    When I took my car to the "experts", they actually told me my car must have been in an accident and there was no adjustment to correct what I was feeling as I drove it.
    Trying to explain to them about moving the Subframe was like speaking in tongues, I even had a VW tech speak to the alignment guy on my mobile phone while I was standing there next to my car at the alignment place, and he couldn't get the guy to understand and ended up telling me to "forget these guys they haven't got a $%#@ clue!"
    I knew this was complete BS as I owned the car since new and there were no accidents - and the car was fine before the sway bar went in. Once I found a decent alignment place familiar with European cars, they loosened the subframe and moved it around slightly and corrected the problem. Once they tweaked the settings, (they even move the Ball-Joints around slightly) the car was tracking straight and felt better than it ever had when driving.
    There's not much movement available, but there is enough movement to make the difference between pulling to one side or running straight. It's a matter of finding a place that has the knowledge and will take the time to get everything "just right" instead of adjusting the tie-rod to a number in a book and handing the car back as though it's your problem.
    Cheers,
    Snowy
    Jun 2008
    Ringwood, Victoria
    Snowy sums it up again
