Results 1 to 8 of 8
Thread: What's wrong with my Bora?
    Mar 2018
    Southbank,Melbourne
    I used to get an error for B2S1 :
    17516 - Oxygen (Lambda) Sensor Heating; B2 S1
    P1108 - 35-10 - Performance too Low - Intermittent
    Readiness: 0010 1001
    I got an o2 sensor and had that changed, the error was gone for a 2-3 months until I got a check engine error again. at first it didn't have any effect on the car especially when the car was warm.
    Recently, it's become horrible. shaking all the time, very low power and high fuel consumption.
    Errors:
    What's wrong with my Bora?-photo5825435079424455103-jpg
    Apr 2014
    Penrith, NSW
    What engine is in your Bora? 2.8L BDE?
    Or the earlier (single coil pack) 2.8L AUE?
    Mar 2018
    Southbank,Melbourne
    not really sure, but it's a 2001 model, v6.
    Apr 2014
    Penrith, NSW
    2001 would be AUE.
    If the engine is misfiring whether it be running lean/rich then it's only going to chew through O2 sensors.
    Misfires can be so many things. But the fact that it's not isolated to 1 cyclinder gives a bit of a clue.
    The AUE uses a single coil pack for all cyclinders, if it's dying this would be my prime suspect. They're about $150 on eBay, or you could try source a 2nd one, think the part no. is 021 905 106C.
    Alternatively it could be the MAF, Camshaft Position sensor or a vaccum leak. Really need more info.
    One thing I would definitely do though is fix this "Brake Switch P0571" and get it re-scanned. Brake switch's can wreak havoc with ESP system and all sorts of crazy stuff happens (loss of power being one).
    Attached Thumbnails Attached Thumbnails What's wrong with my Bora?-capture-jpg
    Apr 2014
    Penrith, NSW
    And dude, get your engine code! Pull your rego papers out and look at the first 3 letters, it will be AUE.... or BDE...
    Mar 2018
    Southbank,Melbourne
    Quote Originally Posted by beale187 View Post
    Thanks bro, really helpful. I wish you were here in Melbourne
    I think my car is neither AUE or BDE. It's AQP?!!
    Vehicle:2001 BLACK VOLKSWAGEN SEDAN
    VIN/Chassis:WVWZZZ1JZ1D457325
    Engine number:AQP000531
    Registration serial number:1177789
    Compliance plate date:08/2001
    Apr 2014
    Penrith, NSW
    AQP it is! Pretty sure they have single coil pack also, same a AUE.
    If you were to take off the pre-cat O2 sensors and inspect them they may give you an idea if it's running too lean (less fuel, indicating fueling issue) OR too rich (too much fuel, indicating spark/ignition issue).
    If they're white-ish or look burnt they're lean.
    If they're black-ish and gunky then too rich.
    I'm still thinking it's a coil pack.
    PM Nick, pretty sure his wrecking a AUE/AQP Bora 4motion. His username is avwboy on here.
    Mar 2018
    Southbank,Melbourne
    To give you an update, I took the car to my mechanic. the first thing he did was checking the plugs. They were totally worn out. after changing the plugs the car runs much better, no shaking, no sudden loss in power..but still horribly fuel efficiency..and you can feel a strong smell of burned fuel when the car is idle coming from exhaust.
    Also he found out that one of the plug leads is short (sparks when removed from coil), called every dealer/aftermarket/wrecker for a plug lead and still no luck
    This is the kind of error I am getting now...no misfire after changing the plugs
    Address 01: Engine Labels: REDIR FAIL!
    Control Module Part Number: 022 906 032 AM
    Component and/or Version: MOTRONIC ME7.1 G 0001
    Software Coding: 00132
    Work Shop Code: WSC 00560
    VCID: 56A360D3B2F286AE9EF-5072
    2 Faults Found:
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-10 - Performance too Low - Intermittent
    16955 - Brake Switch (F)
    P0571 - 35-10 - Implausible Signal - Intermittent
