Results 1 to 10 of 15
Thread: What that ticking ???
    May 2007
    Moonee Ponds
    Whats that ticking ???
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Jun 2008
    South Coast N.S.W.
    Sounds like a vacuum hose could be leaking or has come off ? Does it change in any way when you give it revs ? It's a bit hard to determine from the video, you really need to get your head in under the bonnet to hear it properly.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    May 2007
    Moonee Ponds
    Yeh, It's never easy to determine exactly where the noise is coming from, but it's a bit like a ticking/Scratching...
    I noticed it the other night when I was coming home. It did seem to fluctuate with Rev's, mostly around 2500, I thought it might be from the variable intake rod but I believe they changed that from the MK3 VR6.
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by qsilverza View Post
    It's not a plug lead arcing is it ? Easiest way is to have a look when it's dark and see if there's any sparking anywhere
    Russ
    Russ
    Dec 2007
    Brisbane, Southside...
    It's not your waterpump is it? Assuming that this is my waterpump it sometimes makes a loud ticking noise and you can feel the top of it (circled) ticking away. However it would seem that yours is coming from elsewhere. Just a thought. Jimmy and/or Matt should be able to help you out pretty quick smart I would imagine.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jun 2008
    Ringwood, Victoria
    Trezza, I believe that has to do with your brakes, your water pump is located on the block and is linked in with your timing belt/chain
    From my experience, ticking is a noise associated with valves or sticky injectors. Try and get your injectors cleaned (not with that crap in the bottle, properly ultrasonically cleaned) then see what happens.
    Jun 2008
    Sydney, The Hills
    Quote Originally Posted by Treza360 View Post
    that unit that is in between the coolant and window washer tanks is the activated charcoal filter which filters fuel vapor from your fuel tank and redirects it into the engine.
    Ev.
    Dec 2007
    Quote Originally Posted by EVN-88G View Post
    Ev.
    Woo there we go. Learnt something knew today. Thanks for the knowledge.
    Either way it makes a nice loud ticking noise sometimes.
    Cheers,
    Trent
    Jun 2008
    Sydney, The Hills
    Cheers,
    Trent
    Thank Bentley's manual
    Jun 2008
    Ringwood, Victoria
    Ev.
    I stand corrected
    Thanks Ev
