GMAX offsets FTL. Ive only seen 1 set of rims with decent offset from GMAX. Everything else was spacered off its nut to make it look like a decent fit. 18x10 fit and ive even seen instances of 18x11 being used without a modified rear fender. Look around, especially in the MKIV section on Vortex. Then get your rims and go and show the knobjockey that knocked you back that you can go wide on a Bora.
