Results 1 to 10 of 11
Thread: what OIL to use for the 32
    Nov 2008
    im getting my car serviced in the nxt few weeks and i would like to supply the oil and haldex oil and just curious what would be the best oil to use for the r32? how much oil does the car take?? can i also buy the haldex oil in any motor shop or have to buy from VW specialist??
    any help would greatly apriciated
    Apr 2008
    The Haldex Oil is a specialist "part" as such. http://www.ecstuning.com/Volkswagen-...etrain/Haldex/ has some info on what's needed for a full Haldex oil change.
    For engine oil, any oil that meets the VW specifications (which should be mentioned in your owner or service manual) will do. You own an R32 though, and I'd not be skimping on oil myself if I had one - I'd be looking for a high quality full synthetic personally.
    Nothing to see here...
    Dec 2007
    Brisbane, Southside...
    Penrite HPR5 in my car. Just got it service yesterday by Jmac. The last batch of it has done the full 15000km service life and was in excellent condition when changed. Not dark, thick and and gluggy and still plenty there. Good stuff.
    Jmac will know the full amount required.
    What km service are you up to?
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Nov 2008
    tnx guys i will be supplying all the oils
    Nov 2008
    with the diff and gear box oil does it have to be fully synthetic or can i use semi syn????
    Apr 2008
    Quote Originally Posted by blk99 View Post
    I believe semi-syth is acceptable (in that some semi-synth oils meet the VW standards), but if you've got an R32, I suspect you're not a budget shopper anyway - I'm not saying run off and pay $100+ per 5L for Royal Purple or Mobil 1, but there are some other brands out there that have a good fully synth in their range for more reasonable prices.
