Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: What oil do you guys use?
  1. #21
    Apr 2006
    Hobart,Tas
    Bout 4.5 litres with a filter change.
  2. #22
    Jun 2007
    Quote Originally Posted by 1DUB2C View Post
    how many litres of oil am i supposed to pour into the 1.8t engine? the book says 3.5l i think but i'v read its about 4 or so.
    i reuse the oils in cusomers cars tell em its new
    Are you using the same oil you sell to your customers?
    Just fill it up until it overflows, it'll be right!
    (Tongue firmly in cheek)
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  3. #23
    Aug 2006
    Talking
    hahaha thanks
  4. #24
    May 2007
    Engine oil capacities
    With filter change...4.5L
    VW OEM Part Numbers;
    06A115561B - Oil Filter
    N90813202 - Sump Plug w/Washer
  5. #25
    Jan 2007
    Quote Originally Posted by gtimk5 View Post
    I use Fuchs Super GTO 10W30 MC in all of the late model Golfs here. It matches the VW oil codes and none of my customers have any problems with oil usage. I am currently servicing around 35 TDi Golfs and Polos, and approximately 12 GTIs
    This is NOT the longlife stuff!
    Andrew
    Andrew,
    I assume you wouldn't be using this on an R32 given the high oil temps they achieve?
  6. #26
    Canberra
    I picked up a 20 Litre drum of this from the Castrol distributor. It was $170 for the drum ($8.50 per litre).
    http://www.tds.castrol.com.au/pdf/30...1_b1567_02.pdf
    Snowy.
  7. #27
    Dec 2006
    Kilsyth, VIC
    I am using this Fuchs oil in my Mk3 VR6:
    Convieniently the VR6 takes 5L of oil, so you buy one, drain the old oil, replace the filter and washer, tip the whole bottle in, then pour the used oil into the new container for disposal, nice and simple
  8. #28
    Sep 2007
    I use 'Motul chrono 10w40'
    It's awesome
    feel like different car!
  9. #29
    Aug 2007
    ELF Excellium 10w40.
  10. #30
    Jan 2008
    I used fuch's 10w-40 in my 2l mk4 as well... felt so much smoother after the change. Might try shell helix ultra but - fully synthetic and seemingly highly recommended.
