Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: what coolant to run green or red/pink ?
    Nov 2013
    Goldcoast QLD
    hey all just got a quick question about coolant , my 2001 mk4 golf 1.6 AKL has green coolant in it and i don't think it came factory with green coolant in it ? correct me if im wrong ?
    now if i was to change it to the red/pink coolant that i think its meant to have in what problems if any would i run in to ?
    i would have to flush the cooling system rather well to insure that all the green coolant is out of the system/ heater core before adding the new pink / red coolant yes ?
    any info or input to this would be great as im going to do my thermostat soon and want to buy the correct coolant before i start
    Oct 2013
    Qld
    Pink
    Oct 2013
    Qld
    It has to have pink
    Nov 2013
    Goldcoast QLD
    why pink / red is it more of a anti-corrosion thing , there a blue coolant now also what the go with that ?
    Nov 2013
    Goldcoast QLD
    just had a look in my vw manual that was in the car and it says G12 red coolant only , is it just casue its a anti corrosion thing ? why would green coolant have been put in there instead of red/pink then ? , could this have cause any problems ?
    Dec 2008
    Sydney/Canberra
    Do a full back-flush, and run the G12+ pink in it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Nov 2013
    Goldcoast QLD
    That's what I was thinking , I'll have to flush it rather well but won't i , I have herd if you leave the green in and add the red it turns to goo and clogs everything is that correct ?
    Jul 2007
    Brissy
    As stated already, flush out the green and replace with the correct g12+
    Remove the line from the oil cooler to get the last of it out
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Nov 2013
    Goldcoast QLD
    Yep will do , forgot about the oil cooler thanks for reminding me
    Nov 2006
    Largs Bay, S.A.
    Flush REALLY well like you say - you don't want to mix coolant types.
