Results 1 to 4 of 4
Thread: Changing battery, radio codes?
    Croydon Park, NSW
    I hate to make a new thread for something that should be simple to find an answer for, but my google-fu is not strong enough today...
    My 2001 Bora 4mo has been sitting on the street for a couple weeks with a flat battery. Lights got left on, and was too busy with life to be able to spend time charging it up. A mate came around with a starter last week, but it couldn't deliver enough juice to get the engine turning.
    Haven't tried using jumper leads yet, as I don't own a pair.
    I figured with the battery being dead for a couple weeks, there'd be enough sulfation to cause problems, so a new battery may be in order.
    I've heard that disconnecting the battery will stop my (OEM, tape deck (woo!)) headunit from turning on, and I'll need a code to get it working again.
    How do I get the code? Or is this headunit too old to need one?
    Mar 2010
    Lesmurdie
    Your code should either be in your manual in your glove box on a card, Or failing that you should be able to ring up a dealership and they should be able to tell you the code. My 01 bora has a code but i don't think it was the tap deck one, Unless yours also has the cd player?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    May 2010
    Quote Originally Posted by Back Door Shenanigans. View Post
    x1. Radio code has been getting a workout on the forum lately.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    if the radio is a eurovox you can get the code from Go Technologies. They will charge $22 though.
    Form is here: http://www.eurovox.com.au/downloads/...%20Request.pdf
