Just a question...Did you put in the anti squeal shims when you replaced the pads?
Hey guys well ive got a mk4 2.0l sport anyway i changed my pads about 8,000kms ago if not that. i changed the pads and disks and the pads were bendex pads. anyway they are really now starting to annoy the **** out of me as they squeel more than a girl.
was wondering what pads should i get and how much?
Im just looking to change to any other pads that are good, dont squel and dont cost an arm and a leg.
any help?
I never knew there was sucha thing.
However my brother installed the pads not me. i mearly helped lol.
but the bendex pads are prone to squeaking
Squealing is the pads vibrating. If there's no shims then some copperslip on the back of the pads will help.
I also chamfer the leading edge of the pads a bit, when I fit brake pads.
Yep chamfer the pads is the shot, now you mention Bendix, were they GCTs????? They are normally pretty good, not sure about the normal Bendix.
JMac
Alba European
i recommend Pagid Reds
2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
I recommend putting an R32 motor in your carYou wont have any brake pads to worry about after 8,000 kms
Yep, did you machine the disks when fitting new pads ? or check the minimum diameter of the disk ?
Audi B4 80 Q V6 '94 Race Car !! KEGGED
Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo '01 Gone
i have the shims and everything but its still happening. when i first leave to work thats when the worst obviously because it just started running.
if i change the pads do you recommend to sand down the rotors or that the rotors are possibly the problem?
All i know is just that they are the stock bendex ones.
