Mate a monoblock is DEFINITELY the best of the amps you can get for your sub, if you're looking to power a decent (read: powerful) sub. However - the sub that you're looking at has a NOMINAL (RMS) rating of 300watts at 4-Ohms which isn't actually very much; that will work in your favour.
If you're looking to get some nice speakers as well as a sub, what I suggest you do is get a 4-channel amplifier along the lines of 4x100w RMS. I'm currently running two amps, but my previous setup consisted of a Jaycar 4x100w RMS amp (which i'm still using, just for speakers now) which ran two front speakers on one channel each and one sub on one bridged channel (the other two). That worked for what I needed, and if you're looking at getting that sony sub then a similar amp will do just fine. I woudln't worry about a monoblock for 300 watts.
