Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: Weitec front suspension in - uneven sides
    Jun 2009
    yeah the top nut should be lower than what is shown on the photo. but i still find it complexing that there is such a difference.
    maybe take wheels off and take some photos for all of us.
    are you saying that your strut caps are now flush with the towers in body?
    Aug 2007
    Quote Originally Posted by Dyldo View Post
    but can the strut be an inch and a half out of the spindle cup?
    Spring off its seat will make it sit high mate, might have turned when you were tightening stuff up but would be obvious though
    cheers
    Jmac
    Alba European
    Jun 2009
    How'd you go Dylan?
    Sent from my HTC Desire using Tapatalk
    Jun 2008
    Cronulla, NSW
    going out now to "right the wrong" - first call will be to remove the top hat nut, raise the car to drop the spindle and strut down, and try and seat the strut. here's hoping it works.
    When i do the rears i will chuck in the Blue controller too. Anyone know a good DIY for the rear struts? Have googled some and there is a lot of conflicting info.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Jun 2009
    if you can do the fronts, you can manage the rears!
    the rear shocks are dead easy. 16mm top and 21 mm bottom. the compression of the springs is tricky cause of the **** MkIV design, i have to drop control arms and driveshaft cap, to get the arm lowered enough (maybe not the best way...)
    this one is good but:
    Noah's MkIV VW H&R Coilover Installation HOWTO
    Jun 2008
    Cronulla, NSW
    Nice link dude - i think i found his post when doing my research. Not sure if it covers all-wheel drive cars though?
    Jun 2009
    nah, probably not then.
    as i said, the biggest challenge is compressing the spring and getting enough room to remove and install the bastard.
    to drop the arm, i have to undo a fair bit. and remember to tighten things back up when there is load on the suspension (at rest)
    rears are easy to put in if the spring is shorter, I just wound my adjuster right down and with a little weight on the hib you can just pop the spring in.
    rear shocks are easy to, as someone said, its a bolt bottom, and a plate up top.
    As for your fronts, might be silly, but are you sure you put the top strut mounts in up the right way...?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2008
    Cronulla, NSW
    am really tempted to work from home tomorrow, and in between making some sales calls i might just rip the fronts out (they're both clearly off by the same margin it seems) and take shots. I am 99% sure I put the top mounts in right.
    Would it even be possible that i didn't compress the springs enough and therefore didn't screw the spring hat down enough?
    And wtf is this rear adjuster you speak of?
    Is this rear dust guard in the way of the rear top bolt? I couldn't see anything up there from a cursory glance.
    not screwing it down far enough surely wouldn't make such a big gap though? maybe a few mms?
    height adjuster for the rear springs (im guessing the 4mo is a similar set up to my FWD) your new springs will probably be heaps shorter, and should just pop in.
    I found my rear dust guard wasn't in the way to much
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
