Results 1 to 8 of 8
Thread: Weird Electrics
    gpk_gti Guest
    hey!
    sounds like you have left your blinkers on,which will leave one park light on,,used in europe when you park in a narrow street,usually they still crack your mirror off!hehe
    dont completely understand your no1 issue...
    syncro Guest
    1/ Lane change function. Touch the blinker arm and they give a few flashes to change lanes.
    2/ Park light. Most VWs have this option.
    Nov 2006
    I'd say your indicator controller is failing - Has happened on atleast 50% of the a3/s3s I know and the GTI will no doubt use the same part. And mine was doing the same thing (clicking away without the indicators on)
    The controller is within the emergency button, the part cost me ~$30 from vagparts UK.
    gpk_gti Guest
    hey sov,,that happens to me sometimes,,,blinkers wont work,it stays on.I just give it a jiggle and viola!
    May 2007
    Quote Originally Posted by syncro View Post
    MK4 Golfs don't come with the lane change function, well at least no mine anyway...Not for long though, it is on it's way from Germany!
    Glenn
    Thanks for the responses. Sorry for the bad explanation. What I meant was..
    1.When you turn on the left or right blinker, the indicator lights starts blinking and you also get the clicking sound as per normal. The problem is after it flicks back to its normal position, the “clicking sound” continues for about 30secs. Thanks SoVeReIgN for your info on this. That might actually be the problem.
    With the parking lights issue, I’ll test it later tonight by leaving the signal light on and turning off the engine. I hope that’s it. Still have to get used to the features of it
    Apart from that, we’ve had this car since the weekend (2001 Mk4 GLE 2.0) ….and absolutely loving it!
    Regards
