Results 1 to 10 of 12
Thread: water top up
    May 2009
    Canberra
    water top up
    hi guys, i know this is a very stupid question but i just finish replacing my water temp sensor and all the water was drain from the engine and radiator. where the hell is the water filler opening for the radiator to fill it back up? i cant find where i can top up some water? i cant find the dame thing. it's for bora v6 01 4motion.
    2009 Tiguan TDI and 2007 Passat TDI
    May 2009
    Canberra
    is it the coolant expansion tank? please need answer other wise i cant drivw my car tomorrow coz of no water.
    Dec 2007
    Ermington, Sydney
    Yeah it's in the expansion tank, not on top of the radiator like other cars.
    You shouldn't just use water though! You should have G12+ coolant in there. It's okay to use water for a bit but you shouldn't do it permanently because it wears the hoses out quicker and causes crap to build up because of lack of chemicals.
    G12+ is available through VW or VW related places...not too expensive even from the stealers.
    May 2009
    Canberra
    than you so much mate i will star filling it up. i've got a red coolant, i got it at super cheap, it's specefically formulated for cars using red or orange coolant. this should be ok to use?
    Jan 2008
    Yeah, should be fine to use. if it's a concentrate though, make sure you mix it with demineralised water, not tap water; else defeats the purpose of it.
    Chemicals in it are anti-corrosive, specifically to stop aluminium from wearing. aluminium wearing can lead to cracks in the head = need welding, new head gasket, etc.
    good fun is chemistry.
    May 2009
    Canberra
    ok thanks for that info.
    the coolant is pre mix so i'm good to go.
    thanks again for your help guys.
    Northern Beaches
    To remove coolant is there a bung hole at the bottom of the radiator or do you have to remove a hose to the radiator?
    Thought id ask here than make my own thread..
    Thanks
    Apr 2008
    Quote Originally Posted by revhead1016 View Post
    The bottle probably says what specifications it meets - if it meets the VW G12+ spec, it'll be fine!
    Nothing to see here...
    Perth WA
    Be very careful with the Super Cheap stuff - I don't think it is compatible...
    Jan 2008
    Quote Originally Posted by 4m0ti0n View Post
    from nulon's website: "Use in all cooling systems as a replacement for any red/orange coloured coolant."
    Nulon's red coolant; same stuff supercheap sells.
    http://www.nulon.com.au/products.php...Top-Up_Coolant
