Results 1 to 10 of 12
Thread: Water in rear footwell?
    May 2014
    Gold Coast
    I got in to my car yesterday and put something in the back and found the foot well behind the passenger seat for the rear seats was soaked and had heaps of water in it.
    Any ideas of where it could have come from or how to fix it? I checked my rear door seals and they were all fine so I don't believe it was from there
    Jul 2012
    Sunroof drains?
    Nov 2006
    Largs Bay, S.A.
    Is it only the rear footwell area that is soaked?
    My recent leak originated at the front of the car. (- the cabin pollen filter cover was cracked - that let water flow down through the venting into the front passenger side footwell.)
    May 2014
    Gold Coast
    Yeah it is only my rear footwell that is wet which is why it is confusing me
    Pacific Paradise QLD
    Someone leave a window down in recent rain or door drains blocked and overflowed into car You have had some heavy rain recently in your area.
    Wasnt parked and got flooded when you were absent one day perhaps
    May 2014
    adelaide
    i have the same problem, mine is water build up at bottom door seal. i put towel there to soak the water when raining and that solved my problem.
    Nov 2006
    Largs Bay, S.A.
    Might be worth sitting in the back seat and trying to see where the water is coming in while someone sprays the car with a hose.
    Check the drainholes in the bottom of the doors Open a door and wave it back and forward and listen to see if any water in it. Had a car once that did that. Drilled a couple of holes in the bottom of the door outside the seals That fixed it.
    May 2014
    Gold Coast
    From what i can find out it is the front left sun roof drain, the water goes in but doesnt come out, it is either a block in the drainage channel or a a hole somewhere as water is also getting on my A frame, any idea how to clear the channel? or fix the hole??
    Jul 2007
    Brissy
    Remove the grommet at the door hinge area, and see if the brown hose is still connected.
    If you remove the trim on the base of the a pillar below the glove box you may be able to locate the hose if it has come loose. It is difficult to reattach.
    To clean it out use some trimmer line poked in from the top.
    The grommet can be cleaned by removing and blowing it out.
    Chances are it is blocked at the bottom at the grommet and the water is backing up and finding another route out.
    Once it is all cleaned out and working again, just periodically squeeze the grommet end and see if water comes out.
    Water should drain out quickly after rain etc., if you do see some water then it is likely to be getting blocked again and in need of some maintenance.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
