Results 1 to 10 of 10
Thread: Water Leak Mk4 Passenger side
    May 2012
    I'm sure this has been covered but with this recent rain I have jumped into the car to notice all the way down passenger side (front and rear footwell and boot) is soaking wet. I'm taking 20mm of water sitting there. I have done a bit of research and found it could be a seal on the door but just wondering if anyone else here has found a solution for it.
    Here is a decent link to a fix for anyone else with this issue:
    http://www.btinternet.com/~a_hutton/...Water_leak.doc
    Jul 2011
    South-East Brisbane, Queensland
    Thats a great link. I had problems with my rear footwell, the same problem as in that word document but it was just the lower seal all clogged with crap.
    Dan!
    v5 Bora/Indigo Blue/Remus sports exhaust/JOM coilovers/Lots of DIY bits and Pieces/
    Jan 2012
    I had the same problem my plugs from the sunroof had fallen off.
    Sent from my GT-I9100T using Tapatalk 2
    May 2012
    You mean the drain plugs?
    Jan 2012
    yep the drain plugs in the door jams.weren't connected
    May 2012
    How'd you connect them?? What did you have to pull apart?
    Dec 2008
    sydney
    Drains can be found in the front door opening(both sides), just above the hinges -There's a black rubber grommet/valve which may need a squeeze to dislodge dirt. You can pull them out gently, if there's no pipe atteached put you fingers in the hole and fish the pipe out enough so you can reconnect.Don't pull out too much as it might dislodge the pipe from the sunroof connection.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    May 2012
    thanks dude
    May 2012
    With all the rain overnight the car remains dry...I am guessing it was the door seal
    i've noticed that i'm having a similar problem, my passenger side rear footwell keeps getting absolutely saturated with down pours, however its only just there none on the sides, roof or any where else... i removed the passenger side door trim in the rear to find no wetness, taken off all the trimming around the floor and none of the side is wet and i have no idea where to look next without ripping apart my interior. Would the plugs in the front door affect it?
