Page 16 of 30 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 296
Thread: WA: Back doors 'Boring'
  1. #151
    Mar 2010
    Lesmurdie
    damn! VIC is nothing afaik!
    check how much the wheel bolts stick out the back of the wheel too, might be able to get out of ordering new bolts for the spacers
    Haha i was afraid that WA was the same and was wondering how i get out of it. Thank god for auto one though know more than the DPI do.
    Well ordered some hub centric spacers from dub addiction so hopefully they get here before the cruise
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
  2. #152
    Mar 2010
    Lesmurdie
    So, Finally got around to installing my fk projector headlights. When they first came i wasn't too sure about them thinking the angel eyes are a bit wanky. They seem to be pretty decent with some minor flaws and cheap parts. All in all though now they are installed im pretty pleased with them but i will see how they are down the track.
    This is how the car looked before:
    First step was to remove the bumper by taking out the torx screws under the grille (5 in total), two behind the "fog lights" (one each side), And the screws (and bolts on mine) inside the wheel arch
    And then gently slide the bumper off.
    Onces the bumpers off you have access to the two screws under the headlight, Undo the two underneath then the two on top, Disconnect the cable and wola your headlight should be in your hand (after pulling)
    Next is swapping the levelling motors over. This is done by removing the cable, then twisting the motor and it should just pop out (if you don't understand look at the hole, it should explain it) Once the motors out you will need to disconnect it from the headlight on the ball end by sliding it out of the channel. Install into the new headlights in the reverse manner.
    Levelling motor
    Twisted
    Out
    Installed in new headlight.
    Next you simply swap the fog light and turn signal bulbs over.
    fog light (note should actually pull the connector out of the little black housing
    Turn signal
    All installed
    Have fun trying to install the weather proofing on the back, I suggest using your favourite poking stick
    Installed
    Comparison
    Next step is to simply reinstall them the reverse of taking them out. All though before you go through the trouble of putting the bumper back on make sure they work first
    Cable extender may be needed as the plug has moved
  3. #153
    Mar 2010
    Lesmurdie
    Checking all working
    All back on
    Final result
    All thats needed after this is a headlight adjustment. Will post later. They are quite over the place.
    Angel eyes are growing on me at the moment, Thinking i might do a diy retrofit set with a glass cover to stop the stupid fogging of the lenses. The light output of the new headlights is freaken amazing, So much better than the old foggy reflectors. The lights seem to be of decent quality but the connects are pretty cheap and there are some little design flaws.
    High beams are good. Don't like the look of the outside of the projector but small complaint. Also cant see one of the angel eyes due to the bonnet but that's my fault. If you do get these headlights i'd suggest changing the angel eyes over even though its a huge pain in the ass.
    This is what i had done to the headlights before today.
    Pulled the plug to access all the bulbs for the angel eyes
    Changed to LED's. Make sure you test they work before putting back in as LEDS have polarity
    Installed new globes as they have individual compared to original
    Testing lights work
  4. #154
    nice write up.
    good to see these lights work nicely without HIDs. How much did the H7 globes cost you?
    when you say you changed to LEDs was that the halos? could you access them all (8 in each light if i remember correctly)? was thinking if i was too run this sort of light of removing at least one of the halo rings as I personally dislike them.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #155
    Mar 2009
    Wagga Wagga
    Nice one! Where did you source the LED's for the halos. Been meaning to get some for mine. Looks heaps better!
  6. #156
    Mar 2010
    Lesmurdie
    nice write up.
    Yeah they are quite nice, Not as good as my dads euro but still nicer than stock. After i took the plug out yeah barely. You don't have to have them wired up so they wont run. You could also go to the extent of cracking the lights open (By baking at 180degrees) then removing the halos. I didn't think much of them either but i don't think they look too bad now, the leds i got aren't the super blinding so its not that noticeable.
    Quote Originally Posted by trickysimon View Post
    Bl-leds.com.au, It so happens i have 16 left over if you want them for the price of shipping (also have good fun removing your lights again )
  7. #157
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by Back Door Shenanigans. View Post
    Dude that would be awesome thanks! I'll send you a pm.
  8. #158
    Jun 2009
    Melbourne, VIC
    Good work man. I also think angel eyes are wanky but my car came with them (and I secretly like them) so it's not my fault I have them.
    I need to adjust my headlights. Do I need to take the bumper off too to do it? It is really tight in there...
    VW Bora V6 4motion
  9. #159
    Mar 2010
    Lesmurdie
    Quote Originally Posted by kapowww View Post
    Depends on how they have done the adjusters on your after markets. The OEM ones can be done without removing anything at all, On mine its the two little cog like things on the back with a phillips head on them, Going to be fun to adjust as im not sure even my stubby one will fit.
  10. #160
    Jan 2011
    Bundaberg
    Nice details and pics - good one! I have the Angel Eyes - mostly to keep my Son happy as we work on the car together - Your lights look great - Like your bonnet too...
