Page 4 of 30 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 296
Thread: WA: Back doors 'Boring'
  1. #31
    what you get from ecs? I can see a new grill and lower foglights.
    Cars looking good!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #32
    Aug 2007
    Perth, Australia
    Originally Posted by balkanac
    hi mate, if you want good tints done cheap let me know. the guy comes to your house and does them. He did my golf and my bmw, $200 each, 10% on the golf and 18% on the bmw. Gives you warranty and everything
    interested in this. does he do metallic or ceramic based tints or dye based?
    he is in WA mate
    1991 BMW 318is RED E30
  3. #33
    Mar 2010
    Lesmurdie
    Cars looking good!
    Engine "Bumpers"
    Vacuum Hose Repair Kit ES#279586
    Interior Air Filter, (Cabin Filter) ES#259346
    MK4 Golf / Jetta Hood Latch ES#251244
    Storage Insert For Ashtray - Red ES#260817
    COVER ES#310572
    Ambient Air Tempurature Sensor ES#261224
    Clutch Switch ES#259206
    Hood Pull Release Rod ES#3978
    Shifter Relay Lever ES#4526
    Belly Pan ES#6188
    Mk4 Jetta Fog Light Kit ES#10362
    Oxygen Sensor - Front Position. ES#1899473
    Aluminum Door Pins ES#2784
    303 Aerospace Protectant - 16 Oz. ES#2063109
    303 Wiper Treatment - 6 Packets ES#2063112
    "Short" Floor Mat Screws - Round - Black ES#337204
    Fuel Filter ES#5907
    Carbonio Carbon Fiber Cold Air Intake System ES#2081172
    ECS Billet Aluminum Antenna "Sharon" Style - Black ES#4697
    ECS Tuning Smoke Side Marker Light Kit (Smooth Look Lens) ES#5294
    Fk Mk4 Jetta Badgeless Grille Kit, Black ES#9585
    Exact-Fit Stainless Steel Brake Lines - Full Kit ES#251798
    OE Style Black Cloth Braided Vacuum Hose (3.5x2) 1 Foot ES#1843958
    Bolt M8x14 ES#252215
    Locking Washer ES#7057
    "Long Reach" Triple Square Driver Set ES#9011
    OBDII USB Diagnostic Cable ES#6928
    MK4 Jetta / Golf LED City Light Conversion ES#252058
    Will show all when going on
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
  4. #34
    Aug 2007
    Perth WA
    That's quite a shopping list there Luke!
    '04 BMP MkIV R32 #144
    search getnew
  5. #35
    Mar 2010
    Lesmurdie
    Quote Originally Posted by geoff_gti View Post
    Haha unfortunately still more to come
    Alot happier today. Managed to get my hood latch working all good after ripping apart half the front end of the car. Turns out the mechanism for the primary lock had spun all the way around and managed to block the hood latch from opening. So got that fixed and installed grille and hood pull.
    Installed bits o plastic such as the battery cover.
    Sprayed engine bay with 303 aerospace protector which is absolutely fantastic. Really good stuff that.
    Installed the engine bay "bumpers" (new on the left)
    Tried to install the new clutch switch but found out its slightly different which is annoying. Will trim it down to get it to work.
    Fixed the bolts that i rounded for the door lock module
  6. #36
    Mar 2010
    Lesmurdie
    Continued
    Fitted new stubby antenna
    Fitted the LED city lights
    Fitted smoked side markers. Still a bit unsure on those will see how it goes later on.
    Fitted new ambient temp sensor.....and forgot to plug it in
    And changed over the interior cabin filter which was absolutely filthy as.
  7. #37
    Mar 2010
    Lesmurdie
    Got her detailed today by Dez at autofx. Great guy, great job and awesome finish. Would recommend to anyone in Perth.
  8. #38
    damn, you did order your stuff.
    I was about to order one of the FK grills as well, are they painted? or just plastic finish
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #39
    Mar 2010
    Lesmurdie
    Mine was the black one and im fairly sure they are just plastic finish.
  10. #40
    Mar 2010
    Lesmurdie
    I got this in the mail today.
    Anyone who needs a scan in Perth, I'll be happy to help.
