Yeah watch out for that, shipping cost me more than the extension. Not sure if the Golf one fits the Bora, but if it does I have a spare metal Golf notch filler you can have that came with my FK badgeless grille.
Haha Part of the fun tho.
Um ECS kinda stuffed up and didn't send one so i'm waiting till they have stock then they will send that through, But at the same time i am planning on doing what you said and putting on the boser extension so the filler notch will only be bolted on.
Oh nice you all-ready have yours? Hmm that could be a problem i didn't think of that haha.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Golf MK4 Daily, Nissan Skyline R32 Weekender, Nissan Cefiro A31 Family, Nissan 200SX S14 Racecar
:: MK4 Golf GLE 2.0l 8v Build Thread ::
Fixed vacuum leak by replacing the lines with generic fuel lines. Had a bit of trouble getting it over some of the barbs. Ended up fixing that section but broke the hard plastic down the line so got another vacuum leak to fix. Also changed the fuel lines over. Installed fire extinguisher and opened up door yet again to look at the door module. Found the problem turns out the 4th micro-switch. Managed to fix it but turns out something else has broken and now my door wont lock. So have to fix that soon. Also going to replace the stupid plastic mounts with nuts and washers. Saved about $200 that way so im happy
Vacuum leak.
Old Pipes
Almost ready pipes without clamps.
Fire extinguisher mounted
Door lock module pictures:
Fixed Vacuum leak finally. Now idles well. Also finally managed to fix the door module, it turns out it was the dreaded 4th micro switch and not the corrosion. Replaced the plunger with a little bit of rusted nail and wolah it works again. Light comes on tell me when lights are on and all is good again. Also cleaned it.
Well that buggered up again. Finally managed to get that fixed with a replacement switch by using its parts.
Got some tint put on the car. 38% but **** does it make some difference.
Old
Got some new tyres put on the car. Bridgestone adrenalines. Much better than the bold old tyres on there
Installed some new headlights which whilst not worse weren't much better either
Sanded, wirebrushed, primed and painted ramps.
Before:
After:
Spent the last couple of weeks building a removable tray on wheels for my tool box. Two wheel pivot and two a stationary so i can lift it up by the handle or just push it around on the ground. Bit unhappy with the finish but eh.
hi mate, if you want good tints done cheap let me know. the guy comes to your house and does them. He did my golf and my bmw, $200 each, 10% on the golf and 18% on the bmw. Gives you warranty and everything
1991 BMW 318is RED E30
