Page 1 of 30 12311 ... LastLast
Results 1 to 10 of 296
Thread: WA: Back doors 'Boring'
    Mar 2010
    Lesmurdie
    This is just a work-log of the things i'm doing to my 4mo bora. Most of these I imagine wont happen but given the chance i would like it to. Feel free to post any criticizes or anything not really fussed if no one responds just good to have a record.
    Current Pictures
    Future Plans:
    BBS Lm's
    KW V3s? Suspension kit
    Turbo
    Bora R Front, Back, Sideskirts
    Front fog lights (maybe)
    Blue Haldex
    Respray
    Full HID Kit including auto leveling motors
    Amps speakers and subs
    Fix trip computer (Or install full height trip)
    Exhaust
    Chip
    Cabinaro Intake
    ECS Big brake kit v5
    Speedtech boser hood extension
    Smoked LED tail light (respectable looking ones)
    Smoked side markers
    Current Plans:
    42dd Shifter Bushings (Obtained but require more parts)
    ECS Short shifter (Work in progress)
    Shifter Ends to suit short shifter (Obtained but require clips)
    CV boots
    Previously Done:
    LED Interior lighting kit
    Badge-less grill
    Carpets
    First Aid Kit
    KVW1000 auto up down windows
    W8 Passat interior light
    CCFL Boot light
    AVIC - F20bt Head unit
    DIY resistor Fix
    Fixed Indicator Tick
    Fixed Alternator
    Fixed Cupholders
    Changed MAF
    Changed Spark Plugs
    Green Coolant
    Coolant tank
    Clips
    Speed Sensor
    Arm rest lid
    Headlight restore
    Flushline licence plate screws
    Not Done:
    Coil Packs (Ordered Wrong ones car has intergrated)
    Oxygen Sensor (Ordered Wrong ones)
    Todays Work:
    Got my 42dd stuff today.
    Fitted up my LED Kit as i just couldn't wait. Very impressed with them. Going from a dull yellow to a nice crisp white. Really adds a certain touch the the inside and defiantly the licence plate.
    Before Inside:
    After Inside:
    Before Licence Plate:
    After Licence Plate:
    Rear Dome to red (was the red kit, Still unsure on it, Good as it doesn't distract the driver as much)
    Before:
    After:
    Vanity Mirror To white
    Before:
    After:
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Mar 2010
    Lesmurdie
    Door Light:
    Before:
    After:
    Main Dome Light: (This is the passat b8 one)
    Before: (doesnt really show how yellow it is)
    After (Most likley going to change red map globes)
    Also done the boot but there is no need to show that as all-ready changed.
    Jun 2007
    Eastern Suburbs Melbourne
    i like the sounds of the future plans! could get very expensive though!
    i like volkswagens
    Mar 2010
    Lesmurdie
    Haha, No doubt But will be worth it in the end i reckon. What car isn't a black hole for money anyway
    Aug 2009
    how'd you get the lights out? i've tried and couldnt figure it out! any ideas??
    Mar 2010
    Lesmurdie
    Which ones are you talking about? The 42dd came with some decent instructions for it but i'd be happy to help
    Aug 2009
    back lights above the doors. tried a couple of times with no luck! wouldnt mind changing them to leds as the fronts are already leds
    thanks dude
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by audi-tone View Post
    thanks dude
    There is a spring clip on the front end of the light unit (end with the 'O' symbol), you need to use a flat screwdriver to try and compress that clip and ease it out from that end first. One of mine came out easily the other was a different story.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Mar 2010
    Lesmurdie
    Another good day spend cursing on the car
    Brought some wire, fire extinguisher, paint, and some other pieces for the car today.
    Wire was for the antenna booster mod.
    Pretty good get decent range on it now.
    Fire extinguisher was for safety but still undecided on where to mount it. Most likely going to end up in the boot.
    Paint is for the toe hook mod which will be finished tommorow so pics then.
    Also decided to pull apart my door to see why it wont recognize that its open. Ended up putting it all back together fine after stressing out that it wont lock anymore. Only problem is now the lock cylinder wont stay in the door. Figured out the problem and have to remove it all again to fix. Sigh.
    Door Trim off.
    Window and trim in boot
    Metal Sheet out of door getting further in the crap now.
    Lock module
    Possible cause of problem. Notice the corrode pin. Thats corroded on the connection in the door and on the module as-well. Only solution i think is to replace. Not sure need a bit more info on it.
    Picture of what should be the problem which is cracked solders but seems to be fine.
    Mar 2010
    Lesmurdie
    Also got a big order of parts from ECS Woo.
    Schwaben Torx screwdriver kit
    Ordered the wrong coils as i didn't realize that mine doesn't have individual coils
    Worklog of tommorows work which will be fixing the door and putting in all the new parts
