Results 1 to 10 of 296
Thread: WA: Back doors 'Boring'
    Jun 2007
    Eastern Suburbs Melbourne
    i like the sounds of the future plans! could get very expensive though!
    i like volkswagens
    Mar 2010
    Lesmurdie
    Haha, No doubt But will be worth it in the end i reckon. What car isn't a black hole for money anyway
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2009
    how'd you get the lights out? i've tried and couldnt figure it out! any ideas??
    Mar 2010
    Lesmurdie
    Which ones are you talking about? The 42dd came with some decent instructions for it but i'd be happy to help
    Aug 2009
    back lights above the doors. tried a couple of times with no luck! wouldnt mind changing them to leds as the fronts are already leds
    thanks dude
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by audi-tone View Post
    thanks dude
    There is a spring clip on the front end of the light unit (end with the 'O' symbol), you need to use a flat screwdriver to try and compress that clip and ease it out from that end first. One of mine came out easily the other was a different story.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Mar 2010
    Lesmurdie
    Another good day spend cursing on the car
    Brought some wire, fire extinguisher, paint, and some other pieces for the car today.
    Wire was for the antenna booster mod.
    Pretty good get decent range on it now.
    Fire extinguisher was for safety but still undecided on where to mount it. Most likely going to end up in the boot.
    Paint is for the toe hook mod which will be finished tommorow so pics then.
    Also decided to pull apart my door to see why it wont recognize that its open. Ended up putting it all back together fine after stressing out that it wont lock anymore. Only problem is now the lock cylinder wont stay in the door. Figured out the problem and have to remove it all again to fix. Sigh.
    Door Trim off.
    Window and trim in boot
    Metal Sheet out of door getting further in the crap now.
    Lock module
    Possible cause of problem. Notice the corrode pin. Thats corroded on the connection in the door and on the module as-well. Only solution i think is to replace. Not sure need a bit more info on it.
    Picture of what should be the problem which is cracked solders but seems to be fine.
