This is just a work-log of the things i'm doing to my 4mo bora. Most of these I imagine wont happen but given the chance i would like it to. Feel free to post any criticizes or anything not really fussed if no one responds just good to have a record.
Current Pictures
Future Plans:
BBS Lm's
KW V3s? Suspension kit
Turbo
Bora R Front, Back, Sideskirts
Front fog lights (maybe)
Blue Haldex
Respray
Full HID Kit including auto leveling motors
Amps speakers and subs
Fix trip computer (Or install full height trip)
Exhaust
Chip
Cabinaro Intake
ECS Big brake kit v5
Speedtech boser hood extension
Smoked LED tail light (respectable looking ones)
Smoked side markers
Current Plans:
42dd Shifter Bushings (Obtained but require more parts)
ECS Short shifter (Work in progress)
Shifter Ends to suit short shifter (Obtained but require clips)
CV boots
Previously Done:
LED Interior lighting kit
Badge-less grill
Carpets
First Aid Kit
KVW1000 auto up down windows
W8 Passat interior light
CCFL Boot light
AVIC - F20bt Head unit
DIY resistor Fix
Fixed Indicator Tick
Fixed Alternator
Fixed Cupholders
Changed MAF
Changed Spark Plugs
Green Coolant
Coolant tank
Clips
Speed Sensor
Arm rest lid
Headlight restore
Flushline licence plate screws
Not Done:
Coil Packs (Ordered Wrong ones car has intergrated)
Oxygen Sensor (Ordered Wrong ones)
Todays Work:
Got my 42dd stuff today.
Fitted up my LED Kit as i just couldn't wait. Very impressed with them. Going from a dull yellow to a nice crisp white. Really adds a certain touch the the inside and defiantly the licence plate.
Before Inside:
After Inside:
Before Licence Plate:
After Licence Plate:
Rear Dome to red (was the red kit, Still unsure on it, Good as it doesn't distract the driver as much)
Before:
After:
Vanity Mirror To white
Before:
After:
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
i like the sounds of the future plans! could get very expensive though!
Haha, No doubt But will be worth it in the end i reckon. What car isn't a black hole for money anyway
how'd you get the lights out? i've tried and couldnt figure it out! any ideas??
Which ones are you talking about? The 42dd came with some decent instructions for it but i'd be happy to help
back lights above the doors. tried a couple of times with no luck! wouldnt mind changing them to leds as the fronts are already leds
thanks dude
2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
Previously -
2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
2002 Bora V5
Another good day spend cursing on the car
Brought some wire, fire extinguisher, paint, and some other pieces for the car today.
Wire was for the antenna booster mod.
Pretty good get decent range on it now.
Fire extinguisher was for safety but still undecided on where to mount it. Most likely going to end up in the boot.
Paint is for the toe hook mod which will be finished tommorow so pics then.
Also decided to pull apart my door to see why it wont recognize that its open. Ended up putting it all back together fine after stressing out that it wont lock anymore. Only problem is now the lock cylinder wont stay in the door. Figured out the problem and have to remove it all again to fix. Sigh.
Door Trim off.
Window and trim in boot
Metal Sheet out of door getting further in the crap now.
Lock module
Possible cause of problem. Notice the corrode pin. Thats corroded on the connection in the door and on the module as-well. Only solution i think is to replace. Not sure need a bit more info on it.
Picture of what should be the problem which is cracked solders but seems to be fine.
