Page 15 of 30 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 296
Thread: WA: Back doors 'Boring'
  1. #141
    Jul 2010
    Woodvale, WA
    Yeah chrome imo too. I can do some photos for you if you'd like I'll be snapping lots at the cruise anyway so make sure your car is there!
  2. #142
    Mar 2010
    Lesmurdie
    Quote Originally Posted by saMfish View Post
    Should be Sounds good, always wanted some good non iPhone photos of it.
    Good day today, Had the car less than a day and all ready got it back on jack stands and in pieces :O. Car must have sagged a fair bit since i changed the coils over as im back to hitting the oil sump on curbs and this has happened
    Anyway today was the start of installing the brembos up front and new discs and pads on the rear.
    Car started out like it was trying to fly.
    Then took off all the wheels so it looks like someone stole em
    Started on the rears as i had to paint them to match the brembos up front. Unfortunately there was a 4week wait for red brembos so i had to go with black. Might respray them later on sometime.
    Cailpers removed, pads off, trying to remove the pain in the ass that is the discs. (still unsure on how they are that stuck on there) 3 jaw pullers are a savour for anything like this.
    Everything taken off the rear
    Everything taken off the front.
    Rear calipers ready for respraying.
    Before:
    Wire brushed and cleaned:
    Painted:
    And dangling on the rear hub:
    Thats as far as i got today. Plans for tommorow include fitting new rear discs and pads, fitting new callipers and discs on the front, Fitting the braded stainless steel lines, then pumping 2lt of fluid through the system. Hopefully i cant get it all done.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
  3. #143
    Decent effort to get the guards caught considering the wide body.
    all this talk of brakes makes me want some!!
  4. #144
    Mar 2009
    Wagga Wagga
  5. #145
    Mar 2010
    Lesmurdie
    Well today was..... Insanely frustrating.
    Not bad in terms of progress but just one BIG road block.
    Once again car started out like this
    Everything had been taken off so it was simply time to start installing. First were the rears, Not too hard untill i tried to push the pistons back only to realise you have to turn them at the same time. Another trip up to auto one to find a tool that i had to modify to work. Guy reckons you would only have to turn it, but nope on a VW you have to turn and push! Yay! other than that pretty simple.
    New and old discs and pads
    Disc and caliper on
    Modified cube and g clamp and screw driver!
    Then was the fronts turn. Was fairly simple as all i had to do was remove the brake line at the inner wall and install the new one all ready attached to the calliper.
    New and old
    Caliper and disc on
    Stainless steel brake line
    How the car looks with them on.
    All that was left was the rear stainless lines which where a bit of a PITA as the clips are bastards to put on.
    New and old
    New
    Old
    And finally the car with the wheels on
    And what caused the entire day to be in vein
    So. That leaves me with not a lot i can do. Options at the moment include spacing the callipers with washers which i have no idea if it will give enough clearance, wheel spacers which i think are illegal, Milling the callipers down which runs the risk of ruining them, Machining the inside face of the wheel which i just wont do or going back to stock. Thank god i have a driving course and cruise next week
  6. #146
    oh bummer!
    how much do you think its touching by? like how many mm to clear it?
  7. #147
    Mar 2010
    Lesmurdie
    oh bummer!
    Dont think that much, Its currently stopping the car a fair bit but it didn't do any serious damage to either. Hoping the washers will give enough clearance
  8. #148
    Aug 2007
    Perth, Australia
    don bother with washers mate, just put some spacers on. If they are not massive (and i dont think you'll need massive, prob 5mm max) noone will even know that they are there. My mate went over the pits with spacers on the front and passed
    1991 BMW 318is RED E30
  9. #149
    Mar 2010
    Lesmurdie
    Quote Originally Posted by balkanac View Post
    Yeah they didn't do enough. Apparently according to auto one up to 5mm in WA is fine (God dam sometimes i love backwards WA). Only problem is i don't know to go 3mm or 5mm, suppose its not much difference. Might just go 5mm and buy some hub centric ones from dub addiction. All is not lost thank god.
  10. #150
    Quote Originally Posted by Back Door Shenanigans. View Post
    damn! VIC is nothing afaik!
    check how much the wheel bolts stick out the back of the wheel too, might be able to get out of ordering new bolts for the spacers
