1998-2005 Golf (Type 1J) 1.8 GL, 1.6 GL (Generation), 2.0 GLE (Sport), 3.2 V6 R32
If you have owned or own one of the models above please state your experience with the Golf negativesand positives
Also fill in the below blanks
example
Model: Golf R32
Engine: 3.2 with 177kW
Year: 2004
Any Problems ?: tyres fell off
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
You tell me
I thought as they were built in different factories and had different engine options apart from the 2.0L that they may differ in some respects.
Also could not fit a full description of all Bora models in the title hence my decision to separate the two (this can easily be changed)![]()
- Ben
2008 Jetta 2.0L FSI
what link? it's just text with underline. we're supposed to fill in the details like so:
Model: MY03 Mk IV Golf GTI
Engine: AGU 1.8T with Oettinger chip + K04 upgrade
Year: 2003
Any Problems ?: Front window regulators replaced
Water pump and timing belt replaced at last service (60,000km). Expensive, but before they went which would have been worse!
Excessive wearing on front tyres (due to inner guards coming loose and rubbing on tyres, nothing else)
Throttle body has been reset / cleaned out, still plays up occassionally causing high idling, cruise control won't work, and aircon seems to cut out too
Flex in dump pipe cracked and had to be replaced (sounded worse than a Diesel for a bit!)
Other Features:
R32 bodykit
OZ 18" Superleggera rims
Oettinger pedals
Now with stubby antenna and remote windows! Cheers to Tim @ Dub Addiction and Fuzion!!
'04 BMP MkIV R32 #144
search getnew
Model: Golf GTI
Engine: 1.8T
Year: 2002 MY03
Any Problems ?:
Sunroof mechanism replaced
Microswitch in drivers door lock failed
Throttle position sensor replaced
Cruise control/indicator stalk replaced
Drivers seat material replaced at first service due to wear
Comfort module failed, resulting in passenger power mirror pointing to the ground
Window regulators creaked - didn't fail, but were going to.
N75 valve replaced due to fault
Differential replaced due to clunking
Clutch replaced due to wear
Fuel lines replaced
+ probably more.
79 MK1 GLD
03 MK4 GTI
94 993 Carrera
Model: Golf GTI
Engine: 1.8t
Year: 2000
Problems:
MAF replaced
Coolant sensor replaced
It also has a couple of other small issues at the moment.
2000 Mk IV GTI
Model: MkIV GL Rally
Engine: 1.6 SR
Year: 1999
Problems: Entire passenger side door electrics replaced (window regulator, power mirror, door lock), passenger side door wiring loom replaced, a myriad of squeeks (i carry WD-40!), gremlin in the drivers door windor/door switch module, CCM intermittent problems, possible inner CV joint on drivers side failing....
Model: Golf GTI
Engine: 1.8T + APR
Year: 2001
Any Problems:
Part broke on seat rail, stiff to move forward/back, @37K fixed
Part broke on seat rail again @ 37.1K - still not fixed
Water pump failed @ 65K
CV boot fails every 40K
Tailgate latch mechanism replaced @ 100K
Clutch and flywheel @ 102K
Door locks gone crazy @ 120K
Diff, 1st gear, crown wheel & bearings shot @ 185K
Still heaps of fun to drive.
Model: Golf GTI
Engine: 1.8T + GIAC
Year: 2001
Any Problems ?:
Driver and Passenger window regulators failed
Solenoid for rear hatch lock died
Plug for reverse switch broke (no reverse lights)
Replaced padding in right bolster base and restitched right bolster of drivers seat (wear and tear)
Replaced coolant overflow bottle (common problem)
Clutch rattles sometimes at idle
Engine temp sensor sometimes takes a long time to get going
Owned since late 2002, has been reasonably problem free in comparison to the commondore wagon that we own.
2019 Golf R | 2024 Tiguan 162TSI | 2007 Golf GTI | 2007 Eos 147TSI
2001 Beetle SR | 1976 VW Beetle - BE
2018 Tiguan 162TSI[Sold] | 2016 Skoda Octavia RS[RIP] | 2011 Tiguan 125TSI [RIP] | 2001 Golf GTI [Sold]
2000 Beetle 2.0 [Sold] | + Various old Beetles (1971, 1972, 1974, 1975)
Model: Golf GTI
Engine: 1.8T
Year: 2004
Problems: Coolant bottle replaced under warranty. (Check Coolant Light)
