sick dude.
so OEM+
Good to see you get them on quick after such a long wait!
Car: VW Bora V6 4motion
Wheels: Audi TT (8J)
Front: 17x8.5 et25 (after 25mm adapter) 225/45/17
Rear: 17x8.5 et20 (after 30mm adapter) 225/45/17
Fenders Rolled: Yes
Fenders Pulled: Rears only
Camber: Natural 4motion rear camber
Suspension: KW V1 with rear perches and adjusters removed
Notes: I reckon 18" is the perfect size for Mk4s, but the extra inch of rubber on 17" is the best compromise for my daily baby-mobile. Would also love a bit of rake...
Will get better pics..
sick dude.
so OEM+
Does anyone know a link where i can find a formula to get the rigth adapter size. I see here all final offsets but how do i know what size adapter to use. I drive a mk4 vr6 jetta. Original wheels are 15x7 35mm offset and am getting some17x8 with 52 offset. I need to find out how to calculate for adapters thickness. Thanks in advance for any help.
http://www.1010tires.com/WhelOffsetCalculator.asp
Use that, ignoring the fact u are using the adapters, adjust the new wheel offset to suit the final position you want.
Then as the post above minus the wheels desired offset from its actual specs and that will give you the adapter width.
On a stock height or slightly lowered mk4 I'd suggest a final spec of 8et30 or 8et35f and 8et25 or 30r.
So your going to want 17 or 22mm for the front, and 22 or 27mm rear.
Hi Guys,
I'm tossing up between two sets of wheels to suit a set of 235/40/18 tires I've been given.
1st set:
18x8 5x100 30mm offset front
18x9 5x100 30mm offset rear
2nd set:
18x8 5x100 35mm offset all round
Will be going on a Bora 4-motion, running stock suspension, I'm looking at upgrading to coilovers pretty soon.
Just wondering if either of these combos work with the tires i have?
