Any one else have some decent pics at stock height or lowered on stock wheels?
Finally here are the Supernovas I got from Dylan a while ago still need more more but they are on there way.
Car: FWD
Rims: Supernovas 5x114.3
Front: 17x8 et25 with 20mm adapter GT Radial 215/45/17
Rear: 17x9 et27 with 15mm adapter Hankook 225/45/17
Arch height front: 614mm
Arch height rear: 617mm
Front:
Rear:
The daily
White 2001 Mk4 GTI
GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
Looking good!
Hope your happy with the fitment.
Would love to see white colour coded centres, polish the lips and bolts![]()
Car: FWD
Rims: Denvers 5x112
Front: 17x7.5 et51 with 25mm adaptec hub centric adapters
Rear: 17x7.5 et51 with 30mm adaptec hub centric adapters
Stock ride height (for now...)
Fill out the template as others have done dude, otherwise its a bit pointless for the purpose of this thread.
Spot some Adaptec adapters :p
Awesome. Do you mind throwing a tap on the ground to arch distance before you lower, just for refrence.
Also I thought those were 7.5s? And rubber size? Sorry just want to get it all down.
Ummm I forget the torque settings. I need to check that out, I just go by what feels ok... Whoops
