Page 5 of 29 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #41
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by clifforddd View Post
    loving the white on white!
    Thanks mate, happy with how they turned out!
  2. #42
    Jul 2012
    Car: FWD
    Front: 18x8 et35 225/40/18
    Rear: 18x8 et35 +25mm spacers 225/40/18
    Arch height front: 625mm
    Arch height rear: 640mm
    Height of car (this is without rear spacers)
    With 25mm spacers on rear (I think the front may need attention)
  3. #43
    Quote Originally Posted by tomtom_r32 View Post
    Car: AWD
    Front: 18x8.5 et30 225/40/18?
    Rear: 18x8.5 et30 225/40/18?
    Arch height to ground Front: ??
    Arch height to ground Rear: ??
    Fenders Rolled: ??
    Fenders Pulled: ??
    Camber: stock?
    http://www.vwwatercooled.org.au/foru...tml#post673003
  4. #44
    Quote Originally Posted by dainese View Post
    Car: AWD
    Front: 19x8 et37
    Rear: 19x9 et37
    Fenders Rolled: ??
    Fenders Pulled: ??
    Camber: stock?
    http://www.vwwatercooled.org.au/foru...f-64528-2.html
  5. #45
    Mar 2009
    Wagga Wagga
    Car: Bora V6 4Motion
    Front: 19x9 et33 (after 15mm adapter) 225/35/19
    Rear: 19x10 et33 (after 20mm adapter) 235/35/19
    Arch height to ground Front: 23.6"
    Arch height to ground Rear: 24.8"
    Fenders Rolled: Front only
    Fenders Pulled: No
    Camber: Front No / 1deg extra in rear
    Clearance to front coilover:
    Clearance to rear shock:
  6. #46
    so good ^^ did you mean to include the extra bit about camber though? or just got too excited about it all haha
    Simon and I have been doing a bit of research in to track differences.
    according to the written specs of the 2lt and 4mo, there is no difference in front track, but the rear of the 4mo is 16mm narrower then the 2lt. (think it was 16mm over all???)
    The rear seems to make sense after comparing our cars, but in real life visually it looks that the 4mo has a wider front track then the 2lt.
    So will do more research and add to the first page as this can make a huge difference.
  7. #47
    Mar 2009
    Wagga Wagga
    Yeh, meant to be there. The front is just stock camber where as the rear has -1 degree camber.
  8. #48
    Quote Originally Posted by Lito View Post
    Car: Golf FWD
    Wheel: koya drift teks
    Front: 18x8.5et30 225/40/18?
    Rear: 18x8.5et30 225/40/18?
    Arch height to ground Front: ???
    Arch height to ground Rear: ???
    Fenders Rolled: No?
    Fenders Pulled: No
    Camber: Standard?
    Lito's MK4 GTI
  9. #49
    Car: Bora 2lt FWD
    Front: 17x9 et20 (after 15mm adapter) 205/45/17
    Rear: 17x9.5 et19 (after 20mm adapter) 215/45/17
    Arch height to ground Front: 23.5"
    Arch height to ground Rear: 24.25"
    Fenders Pulled: No
    Camber: Front No / 1deg extra in rear (2.5deg in total)
    Comments: Less (none!!!) rubbing then the teledials due to more space on inside of wheel.
    want it a good .5" lower all round, but need to notch the front drivers side or get a smaller driveshaft first. Drivers side only has 5-7mm between the shaft and chassis, and Id say 3mm of that is because of self notch
    more pics soon
  10. #50
    Car: Bora 2lt FWD
    Front: 16x6.5et43 205/55/16
    Rear: 16x6.5et43 205/55/16
    Arch height to ground Front: unknown subframe and engine cover jsut cleared 100mm from the ground in the first photos
    Arch height to ground Rear: unknown
    Fenders Rolled: no
    Fenders Pulled: No
    Camber: No
    Comments: Clearing a defect, excuse the random toccata on the drivers rear...
    in later photos lowered more.
    More pics later on, subframe approx 60mm off the deck on flat ground. passenger side coilover adjuster clears the tyre by 1-2mm so no more lows possible without smaller tyres or better offsets
