Page 2 of 29 FirstFirst 123412 ... LastLast
Results 11 to 20 of 283
Thread: VWW Official MKIV Wheel Q&A
    Quote Originally Posted by kapowww View Post
    Car: VW Bora V6 4motion
    Wheels: Miro STP-1
    Front: 18x8.5 et25 (after 5mm spacer) 225/40/18
    Rear: 18x10 et15 (after 10mm spacer) 235/40/18
    Fenders Rolled: Yes
    Fenders Pulled: Rears only
    Camber: Natural 4motion rear camber when it's lowered //----\\
    Suspension: KW V1 with rear perches and adjusters removed
    Notes: Obviously would look better dumped but this was the lowest I was prepared to go for a daily. Rear had a bit too much poke. Spacers were smallest I could use for the wheels to clear calipers, no problems hitting the strut with standard offsets.
    http://www.vwwatercooled.org.au/foru...tml#post846579
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Car: VW Bora 2lt FWD
    Wheels: Audi A8 Flat5s
    Front: 18x8.5 et30 (after 15mm adapter) 215/40/18
    Rear: 18x8.5 et25 (after 20mm adapter) 215/40/18
    Fenders Rolled: Yes
    Fenders Pulled: No
    Camber: Rear has additional 1deg each side (approx 2.5deg each side total)
    Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear.
    Notes: Perfect daily spec... proper sized and legal fitment, wheels would have sat inside the guards if my rear beam was centred (is now), looked like factory wheels.
    Would have loved to go lower but rubbing the drivers side driveshaft on the body and wouldnt have lowered the rear anymore without the front going down because cars should have rake
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Wheels: Genuine BBS LMs
    Front: 19x8.5 et30 (after 25mm adapter) 215/35/19
    Rear: 19x10 et32 (after 20mm adapter) 235/35/19
    Fenders Rolled: No
    Fenders Pulled: No
    Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear and wound up 10mm.
    Notes: Had these on at too stages, most of the photos are from GAF11 are with the arches unrolled and rear wound up 10mm
    then back it up for Nats12 with the fronts rolled and rears wound down. made for fun times with 4 people in the car..
    again, would have loved more lows but the front driveshaft was in the way.
    the later photos:
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Wheels: Custom Teledials
    Front: 18x8.5 et30 (after 20mm adapter) 215/40/18
    Rear: 18x9 et30 (after 15mm adapter) 225/40/18
    Fenders Rolled: No
    Fenders Pulled: No
    Notes: Had these on at too stages again, early stages car was a bit higher and didnt have extra camber (Nationals 2011)
    then the car was lowered all round and the shims were left in after the LMs. Arches were also rolled in recent times.
    Will be improving the specs shortly
    for reference, this is what a 215/40/18 looks like on a 8.5 and a 225/40/18 on a 9.
    these fitments meet the manufactures spec believe it or not.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Wheels: Axis Pentas
    Front: 19x8.5 et35 225/35/19
    Rear: 19x8.5 et35 225/35/19
    Fenders Rolled: No
    Fenders Pulled: No
    Camber: None
    Notes: fitted this not long after clearing a defect so car started high again then came down.
    Front poked so much in the first photo.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Wheels: BBS RS
    Front: 17x7 et20 (after 20mm adapter and 5mm spacer) 195/45/17
    Rear: 17x9 et20 (after 15mm adapter) 205/45/17
    Fenders Rolled: No
    Fenders Pulled: No
    Camber: None
    Notes: My first real crack at fitment. not great, but have to start somewhere.
    195/45 is WAY to small in profile for the height of the car or even a slammed mk4.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Quote Originally Posted by trickysimon View Post
    Car: VW Bora 2.8 4Motion
    Wheels: BBS Impuls
    Front: 17x8 et32 (after 20mm spacer) 225/45/17
    Rear: 17x9 et38 225/45/17
    Fenders Rolled: Fronts lightly rolled
    Fenders Pulled: No
    Camber: None
    Notes: Helper springs out of front. Rear adjusters completely out.
    http://www.vwwatercooled.org.au/foru...tml#post847076
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Quote Originally Posted by gringo_54_oval View Post
    Wheels:Audi A8s Polished face colour coded inserts
    Fronts:20 x 8.5 225/30/20
    Rears: 20 x 8.5 225/30/20 25mm spacers
    Guards rolled Front & Rear: No
    Camber:some factory camber from being low
    Suspension:Bilstein Shocks & Lowered Springs
    http://www.vwwatercooled.org.au/foru...tml#post848472
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Quote Originally Posted by MCiN7 View Post
    Car: VW Golf MK4 GL (1.6L)
    Wheels: Reps
    Front: 18x8 et20, 215/40/R18
    Rear: 18x8 et15, 215/40/R18
    Fenders Rolled: Front (no need rear)
    Fenders Pulled: No
    Camber: None/standard
    Suspension: JOM
    Notes:
    Front scrubs guard liners.
    Rear has a little scrub on the inner guards on big bumps.
    http://www.vwwatercooled.org.au/foru...tml#post848719
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Quote Originally Posted by undisclos3d View Post
    Car: VW Golf MK4 GTI
    Wheels: BBS RS
    Front: 17x8.5 et33, adapters 15mm final et18, 205/40/R17
    Rear: 18x9.5 et44, adapters 20mm final et24 215/45/R17
    Fenders Rolled: No
    Fenders Pulled: No
    Suspension: JOM perches out in rear
    Notes: needs to be lowerrrrrrr
    http://www.vwwatercooled.org.au/foru...tml#post850886
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
