front-18x8
rear-18x8
offset-45
tyres-225/40/18
will these wheels work on a 02' Bora 4motion?
front-18x8
rear-18x8
offset-45
tyres-225/40/18
What would be the optimum width and offset you would recommend for an 18" rim?
because the way a mk4 is setup the front wheels 'suck' in when lowering past a certain point.
as the angle of the control arms gets steeper as the car gets lower the track of the front wheels begins to narrow.
while the strut does move in at the bottom also, the top is fixed so about mid way on the strut (wheel the wheel and tyre is closest) will only move in about half what the base of the strut does.
There is a few diagrams on the net to show this, I will try to find one.
still don't get it..
the strut is connected to the carrier which holds the hub and the wheel attaches to the hub.
How can the hub angle to the strut change making the wheel hit the strut?
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
Yep same for me ..... I've put two sets of coil overs and a set of struts with two different makes of lowered coils into the Bora..... The relationship of the wheel to the strut has never changed no matter what height I've had the spring platforms .... The hub and strut are bolted together and the only possible way to have movement between the wheel once bolted to the hub and disc assembly is play in the wheel bearings ....
so in my experience once you have a wheel that clears the strut .... It will always clear unless the wheel bearings are stuffed !!!
obviously if you wind the bottom Spring platform down to where it hits the tyre you have issues ....
Hi all, new to the Mk4 world and thought I'd share my wheel and suspension setup.
Suspension
TA Technix Coilvers (still settling so will up date with final ride height)
Wheels
Porsche Cayenne 18x8 et53
Fronts with 15mm adapters (et38 )
Rears with 20mm adapters (et33)
Tyres
225/40/18 Kumho KU22
Very happy with the way it looks, and a massive thanks to Dylan for all your help.
