Page 23 of 29 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #221
    Sep 2012
    Wonga Park, VIC
    Wheel whores, advice please
    mk4 gti
    will rears 19x9 et37 and fronts 19x8 et37 work?
  2. #222
    Glen Waverley, VIC
    Quote Originally Posted by Swainey32 View Post
    mk4 gti
    Watching (Just wanted to use the naughty smiley for something !)
    Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
    Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
    Weekender/Project:
    Classic Mini 1972
    Dependant #2: Mk4 2001 GTi
  3. #223
    mk4 gti
    Yep should be ok. Would 5 or 10mm spacers all round would be ideal though
    Front will be getting close to the strut
  4. #224
    Mar 2009
    Wagga Wagga
    mk4 gti
    Sure, it will work. What look are you going for though?
  5. #225
    Mar 2009
    Wagga Wagga
    Car: Bora V5 FWD
    Front: 18x8.5 ET20 (after 15mm spacer) 205/40/18 Nangkang NS2
    Rear: 18x9.5 ET30 (after 10mm spacer) 215/40/18 Bridgestone MY02
    Arch height to ground Front: 24"
    Arch height to ground Rear: 24"
    Fenders Rolled: Front only
    Fenders Pulled: No
    Camber: -2 degrees in the front from R32 control arms and hubs. -3 degrees in the rear from IDF drop plates.
  6. #226
    Nov 2012
    Melbourne, VIC
    mk4 gti
    19x9 et25(ish) would sit about flush with the guard man
  7. #227
    Sep 2012
    Wonga Park, VIC
    Cheers fellas
    I found the wheels im looking at were once on a r32 on here, he was running these at
    18x8 et 22 eg 15mm spacers
    19x9 et12 eg 25mm spacers
    Do the r32's have different specs for wheel mounting than the gti? They were sitting nice and flush on his car.
    If this is the case, best location for hubcentric spacers?
    Cheers fellas
    R32 has a narrower rear track, plus camber.
    Front is slightly different setup too but pretty close. Best to compare fwd with fwd.
    I always found 9et30 basically flush on the back of mine. (Check Teledials and merc wheels in the 18x9 section)
  9. #229
    Feb 2015
    Great thread
  10. #230
    Apr 2015
    Kent - Tunbridge Wells
    Superb thread!
    Can you keep the lowered on 17's coming please
    I'm currently running my Bora on 17's but looking for idea to improve the stance and overall look of the car.
    If you could use the template as well that would be great.
