Page 18 of 29 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #171
    Feb 2014
    Batemans bay
    On the oettinger site they list 18 x 8.5 35et as the specs for their 5 spoke rim to suit Bora .... This would also confirm Tims suggested size as a no hassle fitment .... So the search continues !!!
  2. #172
    Iv done two to show the difference between heights and how much difference it can make even over a 2.5-3" drop
    excuse the photos. measurements were taken on level ground, not enough room to take pictures there.
    Car: Bora FWD 2lt, aired out
    Front: 17x7.5et30 215/45/17 good year
    Rear: 17x7.5et30 215/45/17 pirelli
    Arch height to ground Front: 21.75"
    Arch height to ground Rear: 22"
    Fenders Rolled: Front only
    Fenders Pulled: No
    Camber: Front 1deg, but due to being pulled from the bottom it makes offsets more aggressive (approx the same as running a 10mm spacer/ 1deg extra in rear
    Car: Bora FWD 2lt, approx ride height
    Arch height to ground Front: 24.5"
    Arch height to ground Rear: 25"
    Fenders Pulled: No
    as you can see front cambers out, but sucks in the lower it goes
    Rear stays about the same due to the fixed beam, it just rolls forward into the guards
  3. #173
    Quote Originally Posted by LeStig View Post
    yeah will fit fine on springs or coils with a ~30-50mm drop. lower then that and will start hitting coils and inside of the tyre will hit the arch most likely
  4. #174
    Feb 2014
    Batemans bay
    Thanks for the photos Dylan !!! Love your work !!
    Are you running adjustable control arms on the back to correct camber/toe in changes due to ride height drop ??
  5. #175
    nar control arms are in the front.
    I got them to add a touch of camber and to give more clearance (front control arms were hitting the subframe and restricting how low i could go)
    rear is a fixed beam in the fwd cars so cant do much other then shimming on drop plates
  6. #176
    Car: FWD
    Front: 18x8.5 et22 215/35 Nankang ns20
    Rear: 18x9.5 et27 225/35 Nankang ns20
    Arch height to ground Front: just under 22"
    Fenders Rolled: Yes
    Fenders Pulled: No
  7. #177
    Mar 2009
    Wagga Wagga
    Car: Bora V5 FWD
    Front: 17x8 ET24 (after 15mm adapter) 225/45/17 Continental Contact Sport 3
    Rear: 17x8 ET14 (after 25mm adapter 225/45/17 Continental Contact Sport 3
    Arch height to ground Rear: 24.5"
    Fenders Pulled: No
    Camber: No
  8. #178
    Nov 2013
    Bathurst
    Does anyone here run Genuine aristos on Their golf and run spacers? Looking for some reference to order some. been told either 8/15 for almost flush and 10/20 for flush. is this correct?
  9. #179
    Depends how low and what size tyres
  10. #180
    Mar 2009
    Wagga Wagga
    Check my photos with 10/20. Sat pretty flush with 225/40 and 235/40 and 1 degree camber in rear
